bldc_driver_gerber.tgz
BLDC motor driver GERBER files for PCB production
x-gtar-compressed -
33.37 kB -
05/27/2018 at 16:37
Download
bldc_driver.pdf
Schematic of the BLDC motor driver
Adobe Portable Document Format -
20.97 kB -
05/27/2018 at 16:37
Preview
motor_adapter.pdf
technical drawing of the motor to pump adapter
59.60 kB -
05/27/2018 at 16:36
Preview
mount.pdf
technical drawing of the actuator mounting element
24.81 kB -
05/27/2018 at 16:36
Preview
top_block.pdf
technical drawing of the actuator top block
60.23 kB -
05/27/2018 at 16:35
Preview
bottom_block.pdf
technical drawing of the actuator bottom block
66.61 kB -
05/27/2018 at 16:35
Preview
mechanical_dxf.tgz
Set of technical drawings of all mechanical parts in DXF format.
x-gtar-compressed -
28.18 kB -
05/27/2018 at 16:34
Download
