Almost finished...
05/30/2018 at 05:55 • 0 commentsToday I finished soldering, testing, cleaning up, and bagging the Krusty Shitty Add-ons. I'm now waiting on inserts and labels and after that they'll be complete and ready to go for DEF CON 26!
A Quick History
05/29/2018 at 18:18 • 0 commentsI am actually on my second revision of this board. The initial revision had a place for a 0805 Resistor which turned out to be unnecessary. Of the 140ish I'll be bringing to DEF CON approximately 45 will have a ZERO OHM Jumper where a resistor would have been.
The second revision doesn't have this and I carried this knowledge over to my second shitty add-on.
