Always we need to improve things and this is my to do it with my bedroom, it's not because i'm lazy or something similar, i made this project because its futuristic, its confortable and totally usefull.
Control your whole room with your voice or an app, curtains, lights, fan, temperature and more.
Esquema electronico.fzzFritzing electronic diagramfzz - 53.33 kB - 06/09/2018 at 00:48 |
AutomatizacionNueva.inoArduino nodemcu codeino - 9.18 kB - 06/09/2018 at 00:48 |
1-NodeMCU ESP8266 board
1-PIR sensor
1-LM35 temperature sensor
6- 3904 NPN transistors
4-1n4001 diodes.
8-1k ohm resistors
4-5v relays
2-12v relays (can be replaced by 5v ones).
8-Terminal blocks
Some wiring to connect everything and that's it.
I attached the code and the schematics:
As you can noticed on this video i didn't use the same module model, but is the same way to program it and to set the ifttt account with the adafruit one.
