The goal of this project is to build a small very low power RF transmitter. It will reflect RF ambient power to transmit data.
This module can be able used to operate during a very long period of time in harsh environment, like space or high mountain. It's also a way to use the RF fog of our city to do something useful.
The RF Energy can be provided by harvesting a strong signal already present, or by using a highly directional antenna pointed to the sensor and a power amplifier.
It works the same way as RFID, but the range will be higher, a few kilometers.
The module will be a small pcb of 1cmx2cm with castellated holes on the side. It will have one onboard microcontroller, and one RF input/output. The controller will have most of it io/pins wired to the castellated holes, to be able to acquire directly data from external sensors or computer.
I need to find a better way to switch the two impedances.
So I will try with a MOSFET, and also another model of pin diode, but new this time to avoid any problem.
When I will receive them, I will be able to first test with a VNA that I have a consistent impedance switching, and then I will start to make a frequency generator and do the first RF backscatter experiments.
Then I will be able to choose the best uC suited for this task.
When I receive the parts, I will post again.
Today I built a quick pcb with a pine diode and an SMA connector.
The pin diode switch between a sort and an open circuit.
The pine diode I used was not the best choice, but the only I already have in my pile of junk.
I tested it with my VNA, to metter the impedance change.
It's a big fail. My two impedances are near the same ... the impedance doesn't change from a short...
Maybe this IC was damaged, because it was unsoldered on junk, maybe also I heated it too mutch, or even it's because I missed to add a DC blocking capacitor.
I think you should see this EC I (cryptomuseum.com)
It is a backscatter device from the 60s era. I hope you can replicate it.
