Lily Power Pods, TEG + Concentrated Solar
Thermal Electric Generator from concentrated solar, designed to float in water, small scale power anywhere in the world.
This project is a submission for the energy harvesting challenge. My local area is heavily surrounded by over 600 miles of water ways. This device combines three separate ideas. First being solar oven absorption , Second Concentrated solar and Third " TEG" Thermal Electric Modules using Seebeck Effect current generation. Having power harvesting in a pretty package means it can exist in places electronics and wired power normally cannot go. Lakes, rivers, hunting, off grid camping trips and even float these in the water fountains or in pots of water by park benches.
This project is a way to bring concentrated solar to a to everyone with the access to the tools to make them. Version one is only designed for 1 TEG unit as proof of concept. It will generate 1-3.5 volts depending on sunlight. However version 2 is designed to collect and heat 9 TEG units. Scaled up from 60 mm center to a 6 inch center. In version 2 the petals and center must be printed separate assembled.
The inner workings of the Lily Power Module
This is a solar concentrated thermal collector. The light hits the petals which reflects towards the center of the flower frame. The center is a flat black solar collector that can reach a couple hundred degrees in a few minutes. In between the collector and PLA frame there is fiberglass cloth layers that protect the plastic frame from heating up and melting. In the center stacked 1/4" plates with thermal adhesive in between transfer the collected heat to the bottom. On the bottom of the frame is where any TEG modules are adhered. Around the edges they are sealed off from outside water or air with silicon adhesive. Finally there is the last plate on the bottom of the TEG modules that a heat sink may mount to. In my case I am using a 125 watt rated copper pipe heat sink that transfers the heat into the water below the Lily power generator.  in total the heat is collected, passes through the thermal transfer tower, through TEG generating electricity and dissipated through  the aluminum to water heat sink.
Non functional pieces - there is a 1 inch thick disk of foam acting as a lily pad to float the flower frame just above the water surface. The heat sink below the water acts as a weight that keeps the pad constantly upright. From the TEG the red and black DC wires leave to a outside location to a dc to dc power inverter to power a phone by 5 v usb.
topview 3d representation of the head collector and the heatsink on the bottom. I will not draw the details as it will take forever so no good reason.
Portable Network Graphics (PNG) - 243.62 kB - 07/14/2018 at 18:12
Preview
Portable Network Graphics (PNG) - 96.28 kB - 07/14/2018 at 18:12
Preview
Portable Network Graphics (PNG) - 201.51 kB - 07/14/2018 at 18:11
Preview
24 petal lily reflector.stl
This is the newest model as of 7/11 . It has three sets of petals and varrying agle to reflect light at the center about 4-6 inches above the center depending on the angle of the sun.
Standard Tesselated Geometry - 4.81 MB - 07/11/2018 at 14:06
Download
12 petal flower.stl
18 petals, 12 reflective to center collector. Print in any color but the inner face must be ccovered in mylar reflactive film
Standard Tesselated Geometry - 2.20 MB - 07/11/2018 at 13:54
Download
View all 13 files
  • 5 × TEG Thermal Electric Generator Seeback module this uses hot / cold temperature transfer to generate voltage.
  • 18 × PLA 3d printed reflectors These are curved reflectors I am using to focus sunlight heat energy onto the center heat collector
  • 1 × DC to DC converter regulate voltage, step up from low voltage to 5 volt and usb output.
  • 1 × CPU heatsink, $10 on amazon this is the cold end that is submerged into water to attract heat transfer through the seeback modules.
  • 4 × 1/4" aluminum plates heat transfer medium
View all 9 components
View all 23 project logs
  • 1
    Print the Lily frame and petals from PLA or ABS
    print the lily
  • 2
    Clean up any buggars and filament hairs
  • 3
    measure the size of the teg and make a cutout in the lily frame
View all 12 instructions
Jasper Sikken wrote 12/20/2018 at 21:42 point
The LTC3108 TEG power harvester is probably a more efficient power harvester than a 5V dc-dc converter.
Florian Festi wrote 07/27/2018 at 07:04 point
As the leafs have the same width as the collector it should be enough to curve them in one direction. This allows using simpler ways of manufacturing. E.g. bending sheet metal, tensioning a sheet of plastic with a string, bending wire as the border and gluing reflective foil in between.
Florian Festi wrote 07/27/2018 at 06:59 point
I wonder if the leaves could actuated by something heat driven - like a bi-metal strip or a wax motor. The actuator would "try to get into the shadow" and by this moving the leaf to point the reflection onto the collector. That's just the rough idea. It probably needs a lot of thinking before this is actually feasible.
The leaves pointing toward the sun need to be lowered and the leafs on the opposite side need to raised. The leafs on the sides probably need to be tilted along their axis. So you need 2D control over the leafs...
The alternative would be a mechanical solution in which the medium elevation of the sun is fixed and there is something like a ring that is turned my a motor with the right side towards the sun and tilting all the leafs accordingly. But water and intricate mechanics don't mix well.
Florian Festi wrote 07/27/2018 at 07:27 point
May be it is easier to tilt the whole flower. E.g. by  a weight under the waterline that changes the center of gravity off axis.
It could be driven by a set of thermal actuators sitting on top of a pole in the middle over the collector. The ones pointing towards the sun would be warmer than the ones on the opposite side. Having them partially exposed on the top would give some sensitivity toward the vertical angle of the sun.
Florian Festi wrote 07/26/2018 at 09:49 point
To judge your reflector you can just have a look at it from different angles and check what percentage of your field of view shows the black collector or its reflection. All reflector area that is hidden or showing something else it not contributing when the sun is shining from that angle.
Unfortunately I don't see the reflection of the collector in any of the pictures...
Florian Festi wrote 07/26/2018 at 09:21 point
I like the overall idea but the implementation is so inept it don't really know where to start...
Computer heat sinks look the way they look because it is hard to get heat from a metal into the air. Large surface area is needed and the aluminium is transferring the heat much better than air. This is all not true for water. It might be best to just dip the underside of the peltier element directly into the water. Or at most have a very thin heat sink with widely spaced rips to allow convection.
3D printing really isn't the right manufacturing technique for this. It should really be much bigger. Area grows with the square of the diameter. As this will have only a few percent efficiency at least have a reasonable area. May be start with 3 or 4 feet in diameter. This means you need a different way to build your reflectors.
The design is completely unaware that the sun shines from other angles than right above most of the time. Depending on what locations are targeted it should work reasonably at least for a cone of may be 45°. For locations more north or south that may still be not good enough.
Most of the area of the reflector is on the outer perimeter. Half of the area is on the outer 30% of the radius. Having spaces between the leaves there wastes a lot of area - it looks nice though.
I wish I could offer more advice on how to solve these issues but they are hard problems that need quite some thought and research. There is a reason why reflector based solar power plants use sun tracking.
Josh Starnes wrote 07/07/2018 at 19:43 point
I am talking about Fahrenheit  not Celsius
Martin wrote 07/16/2018 at 15:15 point
Then it is best to write this explicitly (F or C) because in many parts of the world reading only "degrees" is understood as Celsius.
So you have not been at a volcanic spring :-)
Martin wrote 06/26/2018 at 08:42 point
How/where do you get rivers with about 60°? The hottest river I experienced was something like 28° in a really hot summer, like 35° air temperature.
But anyway, I would try to use a heatpipe from the cold side into the water instead of active cooling. That saves power for the pump.
Josh Starnes wrote 07/14/2018 at 20:36 point
I took your advice martin and purchased a amazon basics heatpipe heatsink. I think it will work well.
