Version 2
07/08/2018 at 04:32 • 0 commentsI updated the motherboard sled and printed a carriage for the ssd. They nest together nicely but I need to work on cable routine. Also I'm using nylon screws which is a bad idea. I had to cut the wifi antenna a little bit to be able to access the screw holes from the top.
Version 1
07/07/2018 at 21:03 • 0 commentsVersion 1 of the motherboard sled only considered mounting the main board, so the wifi and ssd are loose for now. I soldered some wires to two pads on the motherboard that when shorted turn on the machine. I'm using a toggle switch for now, but will replace it with some other more integrated switch when I design the enclosure.
Wifi
07/07/2018 at 21:03 • 0 commentsI was not aware that the wifi card on this mac was not built into the motherboard. I had to go find it in the lcd panel hinge. Luckily, it and the antena are very compact and transplantable. I did have to cut a cable that snakes behind the screen. Not sure what that was fore - maybe the webcam?
Proof of concept
07/07/2018 at 21:00 • 0 commentsI'm working on printing a test bench sled for mounting the motherboard. The idea is to test everything and fine tune the screw holes before designing an enclosure. The magsafe connector mounts very, although I am considering embedding the power brick into the enclosure as well.
Disassembly
07/07/2018 at 20:59 • 0 commentsI took the entire laptop apart, saving screws for potential reuse. Forgot to take disassembly pictures, but ifixit had all the information I needed.
I should have installed the OS before taking everything apart, but I was still able to attach the keyboard and trackpad to install Debian from a usb stick.
