In this part I investigate the high voltage and mechanical side. All of the high voltage circuits are controlled via the relay board MT2F15-4A (while working out a schematic for this board I all filled out all the pin details from Part 1).
This board is hard wired into the unit and I didn't really want to remove it, I did however, wire up a quick control mockup on a breadboard and use my bench-top power supply to power the low voltage side. Next I (very carefully!!!) applied mains power to board to determine the exact function of each relay. This also confirmed that all of the heating elements are working and that the motor to raise and lower the lifter runs.
Missing from this picture is the plastic bracket that sits above the motor frame, this encloses the high voltage relay board. The bracket also provides structural rigidity when the motor is in operation (see the video at the end of this log for it running).
Next I wanted to understand the wiring of the heating elements, the unit does allow for the outside heating elements to be controlled independently to allow the cooking of crumpets where you don't wish to toast one side as long. Complicating things I discovered that transistor Q5 is a dead short (this was the first control pin I investigated as it controlled the motor). This will need to be replaced, I guess it's about time I took on surface mount components. A lot of care needs to be taken when testing this board there is not a lot of electrical isolation between high and low voltage sides. The outcome is the following schematic describing the operation of the unit. Low voltage side to the left and the mains side on the right.
Pin
Usage
1
+12V roughly, this is actually the raw voltage out of the rectifier, probably closer to 16V.
2
Ground
3
Centre only, applying 5V turns the outer heating elements off. Controls both NC relays 4 & 5.
4
Motor on, applying 5V turns on the motor. Controls relay 1
5 & 6
Heating elements on. This looks to be a safety feature, both pins require 5V to turn on both NO relays 2 & 3. These switch both the Active and Neutral.
And finally the mechanical motor lift. Note the two limit switches tripped by the rotating cam.
With the micro non-responsive it's on to checking if the other components are still working, I've previously determined that the 5V power supply is working, next a check of the various daughter boards to ensure they are all still functioning as well as documenting the functions of each pin.
Input Board
First up the input board, this has the code MT2F15-5A and connects to the P2 connector on the main board.
This board is neatly packaged into a plastic unit that screws into the top of the case providing the input and state display. The clear plastic also doubles as a lightpipe to illuminate the rings around each button.
Nothing particularly interesting here, all LEDs have current limiting resistors and if you look closely the resistors increase in roughly powers of two to indicate which button is pressed using 2 wires. The design however, only allows for a single buttons pressed state to be determined with the left most button being favoured.
Pin
Usage
1
Button +5V
2
Button sense. The measured resistance between pins 1-2 with each button pressed: Stop (Toast/Cancel) - 0Ω A Bit More - 1KΩ Crumpet - 2KΩ Defrost - 4KΩ Lift And Look - 8KΩ No buttons - 18KΩ
3
LED 15
4
LED Common
5
LED 16 & 17
6
LED 19
7
LED 20
8
LED 18
9
LED 21 & 22
Everything seems good on this board, all the LED's light up and buttons work correctly.
---------- more ----------
Progress Bar
This board is just an LED matrix. This board has the code MT2F15-2A and connects to the P3 connector on the main board.
Pin to LED matrix
Pin
6
7
8
1
LED 5
LED 10
2
LED 1
LED 6
LED 11
3
LED 2
LED 7
LED 12
4
LED 3
LED 8
LED 13
5
LED 4
LED 9
LED 14
On the board again it looks to be largely good, although LED 11 is dead.
Control Board
This is where the mains pixie wrangling is performed via a series of relays. The relays control the heating elements and lift motor. The pin out of this board is still a work in progress as it has the high voltage wires connected directly to it and is not easy to remove from the chassis. This board has the code MT2F15-4A and connects to the P1 connector on the main board.
The middle relay controls the Lift motor. While the relays on each side control the four elements.
Pin
Usage
1
+12V (roughly)
2
Ground
3
+5V - Centre heating elements only (turns off outside elements)
4
+5V - Motor on
5 & 6
+5V - Elements on, both are required to turn the heating elements on.
Main Board
The main board holds the power supply, toast level control, buzzer and MCU. The board has the code MT2F15-1A, in addition to connecting to the daughter boards it also has a power supply input (~13V AC) and inputs from the limit switches used to determine the position of the lift motor. Note in these photos the ceramic oscillator has been removed.
The MCU is a Crastal 28 (spelling is correct). The large cutout is to allow for the motor.
With some Google Foo and results filtering the MCU provided a lot of information about the origins of this product. The "Crastal" MCU is either a custom or custom labelled part for a company called Crastal Technology based in Shenzhen China. The company does product design and manufacturing for many big brands including Breville (they also appear to have a number of their own products including Sauna Pants?!?).
The MCU pinout is fairly straight forward
Pin
Usage
Pin
Usage
1
Connector P3, Pin 6 - LED 1-4 Common
15
Connector P2, Pin 9; Connector P3, Pin 1
2
Connector P3, Pin 7 - LED 5-9 Common
16
Connector P2, Pin 8; Connector P3, Pin 2
3
Connector P2, Pin 4 - LED 15-22 Common (Input board)
17
Connector P1, Pin 6 - Heating elements on
4
Connector P2, Pin 3 - LED 15
18
Connector P1, Pin 3 - Centre elements only
5
Buzzer
19
Connector P1, Pin 4 - Motor
6
+5V
20
Connector P1, Pin 5 - Heating elements on
7
GND
21
AREF? (+5V)
8
TBA
22
+5V
9
Connector P2, Pin 2 - Buttons (Analog)
23
XTAL
10
Up limit switch
24
XTAL
11
Down limit switch
25
NC
12
Connector P2, Pin 7; Connector P3, Pin 3
26
NC
13
Connector P2, Pin 6; Connector P3, Pin 4
27
NC
14
Connector P2, Pin 5; Connector P3, Pin 5
28
Connector P3, Pin 8 - LED 10-14 Common
From this we can see that all of the LEDs are in a matrix not just the progress LEDs. The pinout is "similar" to a ATMega128 which I might end up dead bugging to the board and soldering wires over into the appropriate pin locations.
Next time the electro-mechanical and high voltage components.
First steps were to trouble shoot what was actually wrong with the unit. Prior to stopping working after applying power the unit would turn on all the LEDs and then the progress bar would light fully before rapidly reducing to zero. It was no longer doing anything on power up.
After removing the case and checking for anything obvious eg anything burnt etc. The first thing I noticed was like any appliance in Sydney (and I'd assume many parts of the world) if it's warm and contains food, it will have signs of cockroaches and this was no exception. However it did seem confined to the crumb trays and the high voltage side. Judging by the few dead roaches they likely didn't survive the toasting cycle. Nothing however, looks to have obviously failed.
All the internal wiring is high temp fibreglass braided, there is a small transformer that leads to the mainboard along with a number of daughter boards. These a broken up into the main-board that includes the low voltage power supply, a micro and the toast level control, a input/LED board (buttons with lighting), a LED progress bar board and finally a relay board for switching high voltage components.
A quick test with a multimeter shows that the transformer is good and is putting out ~13V AC. Following "thou shalt check voltages" the AC input is rectified with the raw DC being supplied to the relay board as well as a 5V regulator providing power to the micro. Both of these voltages are present and stable. I also at this point wire up an alternate AC input plug that I can plug into my bench-top AC supply to more safely power the main board.
After testing various points and giving the unit a good clean it is looking very much like the micro is not working. This rules out a "simple" repair.
By using our website and services, you expressly agree to the placement of our performance, functionality, and advertising cookies.
Learn More
