Hi guy today we make Coil Winding Machine. Please check on description, My comment on Youtube and do step by step you will get good Coil Winding Machine.. I try to make the PCB by Eagle software and order PCB online on https://jlcpcb.com/. After that the circuit work great and i share it for you. i hope you can do it at home
The PCB i take from http://paja-trb.cz/konstrukce/pocitadlo_jizd.html
He wanted to monitor the actual number of trips (uphill) separately up and down. So it canot use for make the winding machine. I use PCB and edit the code, after that it can use for count widing machine. The code below has 2 version. One orginal for actual number of trips (uphill) separately up and down. One i has edit for count winding machine.
You can download it in description. It include PCB layout,schematic and Gerber file. Or you can dowload below
https://drive.google.com/file/d/1dvBq-4qQwhIQac5vPaeNsx67cF5ETCXr/view
I make the gerber file by Eagle software and upload them to https://jlcpcb.com/ for order PCB online. Only 2$ /10pcs for 2 layer PCB and Big Discount on First order Shipping https://jlcpcb.com/ Upload your gerber files and fill in Shipping Adress then click PAY. After 2 day. I received the PCB 10PCS it look great and beauty
youkito1991
Tinkers Projects
