Detailed design analysis on the power management and software systems used on the SOLoRa board will be presented in an upcoming post.
The hardware features of the SOLoRa board include:
- Low-cost components.
- Inexpensive standard components in novel configuration are used instead of specialize energy harvesting ICs
- Easy (ish) Assembly.
- QFP package processor and 0603 Rs and Cs.
- Can be soldered by hand using standard soldering iron. One exception is the accelerometer, which can be soldered using a reflow heat gun and a little training.
- Arduino compatible: Uses the same device as the Arduino Zero. Uses Arduino bootloader.
- Featherwing compatible: Can use with Adafruit’s Featherwing expansion boards or use the header for a protoboard mezzanine
- Multiple power options to targeting additional IoT applications, particularly field applications
- Solar. The main subject of this blog.
- a CR123 battery clip for a LiFePo4 battery used as a power reservoir. (~400mAh)
- On-board regulator charges LiFePo4 to constant voltage.
- Solar cell size constrains max charge current.
- Rechargeable Li-Po or external battery pack
- For standard indoor applications
- On-board USB micro connector and charger IC
- Lithium (primary cell)
- Battery clip will also house a standard CR123 3V Lithium, which has ~1000mAH capacity
- USB 5V for desktop development (or use with a USB battery bank?)
- On- board adjustable regulator
- Change Resistor values to adjust VDD
- Adjust to 3.3V to regulate Li-Po or external battery pack and USB 5V
- Adjust to 3.5V for LiFePo4 constant voltage charging.
- Small size: 2.3 x 2 inches
- Has mounting holes to match an inexpensive water tight enclosure
- All components mount on one-size only. Bottom is free to increase mounting versatility.
- 2-layer board, cheaper to fabricate.
- Optional on-board sensors, indicators
- 3-Axis Accelerometer
- Temperature
- Programmable Red LED
- Development Options
- Arduino IDE (use as an Arduino Zero)
- Atmel Studio
- Atmel Studio has Arduino templates to program like Arduino, or use standard C form
- Full debugging capability (breakpoints, watch variables). a $20 JTAG debugger hardware required for this feature
Joe Miller
Hi Joe, I'm from the SoLoRa meetup, and saw your board.
Thanks for putting all the detail on the design. I did find your sw examples https://github.com/180Studios/SOLoRa_TTN
I'm just wondering, if they are uptodate, reasonably recommendable. I used a LMIC tutorial from elsewhere but it had some unreliabilities in it, so scouting around for a working reference example. many thanks Neil
