P1 - Buddha Tape feeder
3D printable Pick and Place tape feeder for the Arcus-3D-P1.
A 3D printed reconfigurable head actuated tape feeder with the goal of not requiring any additional electronics. (but you could drive it with a servo if you like)
Should handle 8mm-24mm wide tapes and components of up to 8mm depth.
Sub-project of: Arcus-3D-P1 Pick and place for 3D printers
  • Came in at <tape width> + 4mm.  So for 8mm tape, it consumes 12mm of width which is just 1mm more than the reel the components come on. If you stack more than one, you can go thinner for the base plate.
  • Drives the tape with a sprocket on the release stroke of the feed lever to the same position.
  • Supports the tape up against the cover window from both edges, and centers it.
  • Removes the cover tape and has an integral slipper clutch so you can adjust the tension of the tape pull.  Rotation of the cover tape removal can be switched from during tape advancement to opposing tape advancement by changing 2 parts.
  • Supports tapes up to 8mm depth relative to their top surface at the same depth, with no adjustments.  Supports tapes up to 24mm wide by changing 2 parts, which are parameterized.  Tapes with feed holes on both edges are supported.
  • All cams and ratchets are spring loaded and positive acting (force on them engages them more).
  • For hardware, it requires two skateboard bearings, two M3 bolts, two M3 nuts, one (optional) O-ring, a 20mm length of 2.0mm piano wire, 100mm of 1.0mm piano wire, and a pen spring.
  • Must be printed with a relatively fresh 0.3mm nozzle on a well tuned 3D printer.  Accuracy of the ratchets and tape drive ratchet wheel are critical.  The rest you can fudge a little on, but 0.3mm will work the best because the whole model is done as multiples of 0.3mm.
View all 6 components
  • New and improved, hopefully.
    MasterOfNull08/31/2018 at 03:13 4 comments
    Got off on a tangent trying to make a new feeder using a pin drive.
    It sucked, I scrapped it.
    So, I stole some things from that design that actually worked, and updated this one.
    Advances with vertical motion now, both cover tape removal and tape advancement happen on release, and now uses a pinch roller for cover tape removal.
    It also uses smaller 4x13x5mm bearings now so the whole thing is smaller and faster to print without giving up maximum part height.
    I was also able to ditch the connecting rod in favor of integrated gearing between the drive ratchets, and I switched from a pen spring to using hair bands.  The latter will be much easier to adjust the force required for feeding.
    Printing.
  • LEGO (compatible)!
    MasterOfNull08/19/2018 at 04:51 0 comments
    So a little bit of background first.
    I was looking at how I was going to have to mount my tape feeders to the top of my build surface and not liking it at all. I was looking at an array of laser cut holes, a statically mounted DIN rail needing additional height, or some other nonsense.
    Then this idea popped into my head and I went with it.
  • LEGO (compatible), All rights reserved.
    MasterOfNull08/18/2018 at 02:44 0 comments
    From henceforth when I say the word LEGO, please replace that with LEGO compatible.
    Getting that out of the way, I've been a big fan of the building blocks since when they were cheap(er) and I firmly believe they are part of the reason I am who I am.
    Ok... mushy flashback aside, I've found a logical use for them here.
    I wasn't liking the need to put holes all over my base to mount feeders.  I went the laser cut route, then the DIN rail route, but then after a quick Google (yes, it's a verb now), I discovered that the dimensions of modern day LEGO blocks were exactly 8mm spacing between 'pins'.
    This prompted a current quest to make a half spacing LEGO mount, so I can have 4mm spacing, which will give me the ideal mount for my feeders given any width.
    Iterating on this, until it is a perfect fit, then it will go under my feeder.
    Third try, getting close.
    EDIT: Not close enough.  After much iteration, I've determined that the tolerance required for the interference fit I designed here is less than 0.05mm.
    That is bound to generate significant amounts of swearing, on a 3 hour print.
    I think I really need to redesign this to be a bending interface instead, like actual LEGO parts.
    That still would be really hard to do as a side wall, so I think I'm going to split this into its own part and print it vertically for attachment to my feeder later.
    I'll do that and print it while I'm sorting out the RC servo PWM code tomorrow.
  • Tweaks
    MasterOfNull08/09/2018 at 07:07 0 comments
    I need to move the cover tape slot back and turn the cover tape pull distance up a bit.
    The latter will change a good number of dimensions.  Hold off on printing for now.
    I'll have the updated files up by Saturday.
    EDIT: I took one to the local Makerspace and Sim had a mounting suggestion which I really liked.
    I'm adding a DIN rail mount to the bottom.  It was also 'sticky' after my changes.
    I'm not done with it, and currently busy with the P1.  I'll get back to this when I'm ready to mount one.
    EDIT 2: I had a bit of a eureka moment this evening, and I'm changing the mounting again.  I'll keep the old bolt-down one for those who don't want to go in the direction I'm heading, but I personally can't wait to try it.
    I'll give you a hint.  Lego's have 8mm pin spacing.
  • Bender Bending Rodríguez
    MasterOfNull08/04/2018 at 21:13 0 comments
    I made a little throw-away template you can use for bending the connecting rod/getting the connecting rod length and the pivot depth 'correct' more easily.
    Here is what the connecting rod should look like when done, and fit the length of the connecting rod template holes.
    Oh... and don't forget to put the spring pivot part on the rod before bending the second end.  It's rather impossible to get it on after bending..
    I've also discovered it is much easier to make the first bend at a 90 degree angle to where it's supposed to end up, so you can get the perfect depth for the pivot points and then rotate the resulting end back to straight.  I'll post a video later.
    The connecting rod template is in the source now, and rendered as a part on Github.
  • Success!
    MasterOfNull08/04/2018 at 01:46 0 comments
    After about 20 different versions, I've finally honed the tape cover to a point I'm satisfied with it.
    It bends eventy, and just the right amount, despite having two big missing bits nearly across it.  That was a lot harder than I thought it would be...
    Three reasons I put so much time into this:
    • Since it's printed flat,, it's the bottom, aka.. perfectly flat/smooth surface, that is riding against the tape.
    • This is the only component which experiences sliding of the tape, and so the only component you should have to replace.  I wanted it to be small and removable.
    • You can adjust the dimensions of the hole the part is picked from so as to reduce the tendency of parts jumping out before they are picked.  Aka, use a custom cover for each part if you like.
    So without further ado... here is the finished product and my video with rambling explanation.
  • Tape cover!
    MasterOfNull08/03/2018 at 08:07 0 comments
    Still dialing the tape cover in.  I've found out it's rather hard to design a bendy thingy with two holes spanning nearly across the middle of it, and one hole that goes all the way to an edge.
    Everything else is sorted.  The tori solution for cover tape tension adjustment is good, ratchets are tuned and working perfectly, and moving the spring to the connecting rod and moving it up top worked great.
    Al.....  most...... there.
  • It's the little things..
    MasterOfNull08/02/2018 at 22:33 0 comments
    Moved the return spring to be coaxial with the connecting rod, and reworked everything around that.  No more bridging required for the tape_drive ratchet.  Where it connects to the connecting rod is a bit thin now.  It's strong enough for sure, but long term wear may be an issue.  I left it that way as the top surface lines up perfectly with the center of my spring mount which can be flush with the bed, and also the matched top surface of the lever arm then.  That means the connecting rod is a straight bit of wire under tension.  Easy is better, probably.
    Moved the servo down a bit to line up with my slot for driving it and added a second set of mounting holes for sharing a servo between two feeders.  The slot drive makes this possible.  You engage a feeder by pulling, pushing just slides in the slot so both servo connections can be 'simple'.
    I broke out the signature filament as I think this may be 'the one'.
    I also added 0.2mm of clearance to the ratchet teeth/ratchets so they engage a tiny bit better, and changed the ratchet spring length so it is now a function of tooth count and not an angular percentage.
    Having the spring length be an angular percentage meant that larger diameters got longer arms, but the 'springiness' was constant due to the arms being exactly 2*<nozzle_dia> in thickness. So the ratchets for the smaller diameter cover tape spool were a bit too clicky, and the tape drive sprocket was not clicky enough.  Using tooth count instead solved this nicely.
    Of course this means reprinting nearly everything as changing the ratchet arm length changes the pin mounting holes, the sprockets, the drive ratchets, and the pin ratchets.  Basically everything but the tape idler spool.
    About half done.
  • Clutch, was too good..
    MasterOfNull08/02/2018 at 05:10 0 comments
    The useable range of the clutch was too small, and worse, it happened while the tension nut was way too loose.
    Cover tape tension varied from good enough when just barely touching, to way too much torque, at just 1/4 turn more of the tension nut.
    I modified the cover tape idler so the clutch slot is now two tori with both slightly askew, so the O-ring should have two high spots which engage first.  I also reduced the spring tension on the O-ring as much as I could by putting it back on the bearing directly.
    I also took a trip to Walmart to scavenge some more pen springs.  Eight clicky pens for like $1, but the springs are stronger, longer,  and worst of all, they don't like to stay in-line when compressed like the one I had before.  I'll need to plan for sucky springs I think, so I'm modifying the design so the spring is coaxial on the connecting rod.
    Moving the connecting rod will be a good deal of work though.
    In the meantime I've been iterating on the slot cover, trying out different bending amounts lengths, etc.  Don't have a perfect one yet.
  • Clutch
    MasterOfNull07/31/2018 at 20:25 0 comments
    Revised the clutch so the cover idler gets more meat on the bearing.  It needs to be a press fit as the hub pulling down on it is what provides the clutch pressure.
    Advantage in that now it's completely obvious where the O-ring goes, disadvantage in that now you have to use the right size.  Before it could handle a pretty wide range of thicknesses as it was a wedge.
View all 34 project logs
Oleg Perevyshin wrote 05/13/2019 at 18:37 point
Hello!
Is there a version for repeating? I want to try this feeder.
MasterOfNull wrote 05/13/2019 at 22:30 point
The source that is currently up includes changes that did not work out so well.  But you can rewind time back to this version on Github.  Let me know if you need some help.
Morning.Star wrote 10/04/2018 at 07:31 point
Lol how many of these things are you developing in parallel? ;-)
AVR wrote 10/04/2018 at 12:41 point
Tape feeders are like the only thing that makes doing a nice PnP hard, so I for one welcome as many attempts at an open source one as possible, I want to use a really good open one in my build.
Oleg Perevyshin wrote 08/16/2018 at 13:04 point
I wrote a proposal in the group about the use of other bearings. What do you think?
As an example 603 (3x9x5mm), 624 (4x13x5mm) and HK081210 (8x12x10mm), then you can use a thicker tape.
MasterOfNull wrote 08/22/2018 at 04:23 point
I've been thinking about this, and I think I'm going to do it.  The 22mm OD of the current bearing wastes way more space than it should.  I do need the 8mm height though, and I need a solid hub so no needle bearings.  I may have to use two.  I have enough 624 bearings on hand to give them a try.
anthony.webb wrote 07/27/2018 at 05:10 point
Thats pretty neat, I'd love to print and try one!
MasterOfNull wrote 07/27/2018 at 05:26 point
I just printed the first base.  I had messed with the tooth count of the sprocket earlier, and the design being parametric, everything else was based on that.  it's *a lot* smaller than I thought it would be.  I'm going to scale it back up a bit as right now max tape depth looks to be about 4mm.  Stay tuned!
MasterOfNull wrote 07/29/2018 at 02:21 point
New source is up.  Everything is fully parametric now.
Nixie wrote 07/20/2018 at 00:15 point
That's really nice! Good job!
MasterOfNull wrote 07/21/2018 at 00:22 point
Thanks, it's coming along.
