Z80-MBC2: a 4 ICs homebrew Z80 computer
Homemade 8MHz Z80 SBC, 128kB banked RAM, RTC, SD (HD emulation), Basic and Forth interpreter, CP/M 2.2 and 3, UCSD Pascal, Fuzix and more...
The Z80-MBC2 is an easy to build Z80 SBC (Single Board Computer).It is the "evolution" of the Z80-MBC (https://hackaday.io/project/19000), with a SD as "disk emulator" and with a 128KB banked RAM for CP/M 3 (but it can run CP/M 2.2, QP/M 2.71, UCSD Pascal, Collapse OS and Fuzix too).
It has an optional on board 16x GPIO expander, and uses common cheap add-on modules for the SD and the RTC options. It has an "Arduino heart" using an Atmega32A as EEPROM and "universal" I/O emulator (so a "legacy" EPROM programmer is not needed).
It is a complete development "ecosystem", and using the iLoad boot mode it is possible cross-compile, load and execute on the target an Assembler or C program (using the SDCC compiler) with a single command (like in the Arduino IDE).
* NOTE TO THE READER *: Due to a text size limitation of the Hackaday. io site a few chapters have been moved to "Log files". In this case you have just to click on the link of the chapter's title to open a new tab and read it.
* * HARDWARE OVERVIEW * *
The needed ICs for the "base system" are:
  • Z80 CPU CMOS (Z84C00) 8Mhz or greater
  • Atmega32A
  • TC551001-70 (128kB RAM)
  • 74HC00
If you want the 16x GPIO expansion (GPE option) add a MCP23017 too.
The schematic and the BOM are attached in the Files section. The MCU Atmega32A is used as universal I/O subsystem, as Eeprom, and as reset and 4/8MHz clock generator for the Z80 CPU.
Inside the Atmega32A it is flashed an Arduino bootloader taken from here, and it is possible to use the Board Manager of the Arduino IDE to "import" it.
Flash the Arduino bootloader at first (with the method you prefer), next you can upload the IOS "sketch" (the I/O Subsystem that interacts with the Z80 bus and "virtualizes" the EEPROM and all the peripherals seen by the Z80 CPU) using Arduino IDE.
You can use the on board ICSP port J3 (also called ISP port) to write the bootloader, but remember to disconnect any other connector when using it. Also both SD and RTC modules (if present) must be removed from the board when the ICSP port is in use.
As clock source for the Z80 CPU it is used the 16MHz Atmega32A oscillator, so the "external 16MHZ osc." bootloader variant must be chosen when flashing the bootloader from the Arduino IDE!.
The 74HC00 is used as RS flipflop to stop the Z80 CPU during I/O operation, giving the needed time to the Atmega32A to interact with the Z80 bus, and as part of the MMU.
Note that only the CMOS version of the Z80 CPU can be used here. This because only CMOS version, under given condition that are respected in this schematic, has logical levels compatibles with Atmega32A and 74HC00.
NOTES ABOUT THE COMPONENTS
You should use a  Z80 CMOS speed grade of at least 8MHz for full speed, but setting the clock speed at 4MHz you can use a 4MHz Z80 CMOS version too (or you can try to overclock it at 8MHz...). The 74HC00 can be substituted with a 74HCT00 if you already have one. The RAM chip TC551001-70 can be substituted with any suitable 128kB SRAM).
Please note that the USER led  * must * be blue or white (or pink... I've some pink leds that seems to have a Vf like blue one. May be I'll do a board with them...) just to be sure that V(forward) is >= 2.7V (otherwise the USER key may not work as expected).
The J4 connector (AUX_P) is used as auxiliary power connector when an add-on board (uCom or uTerm) is connected.
The three solder jumpers (SJ1-3) on the bottom side are not currently supported and must  be left opened (as stated in the schematic).
THE GPE OPTION (GPIO CONNECTOR)
It is possible to choose to populate on the PCB a GPIO port expander (U5) to add 16 bidirectional GPIO pins. The GPE option (see the schematic) can be used with the SPP Adapter board (see the paragraph: SPP (STANDARD PARALLEL PORT) ADAPTER BOARD).
The pinout of the GPIO (J7) connector is:
THE SERIAL PORT
The  SERIAL port (J2, see schematic) can be connected with a TTL-RS232 adapter, or with a serial-USB adapter.
I've used a serial-USB adapter that acts also as power source for the Z80-MBC, and has the DTR signal for the "autoreset" driven from the Arduino IDE. For a terminal that has a serial TTL port no adapter is needed.
Of course to upload a "sketch" from Arduino IDE you need to use a serial-USB adapter connected to the SERIAL port.
Note that the RTS and CTS pins of the SERIAL port are not currently supported and must be left not connected (as the NC pin!).
The 3V3 pin of the serial-USB adapter must be left disconnected  (if present).
You should use those Serial-USB adapters that have the DTR pin on the connector. It is suggested to have also the CTS/RTS signals available for future upgrades.
Please note that all the pin...
Z80-MBC2 User Manual - D081023-R280424.pdf
Adobe Portable Document Format - 11.66 MB - 04/28/2024 at 15:52
Preview
SD-S220718-R290823-v2.zip
The content of the microSD needed to run CP/M 2.2, CP/M 3.0, QP/M 2.71, UCSD Pascal, Collapse OS and Fuzix with IOS S220718-R290823 (More info in the Changelog.txt file inside)
Zip Archive - 5.81 MB - 10/06/2023 at 10:40
Download
S220718-R290823_IOS-Z80-MBC2.zip
The sketch for the IOS (with the needed libraries). Unzip into a folder and open the .ino file (with Arduino IDE). IOS must be uploaded into the Atmega32A flash. Adds support for Fuzix OS and the SPP Adapter board (more info in the changelog inside the .ino file).
Zip Archive - 43.75 kB - 09/24/2023 at 11:59
Download
S220718-R290823_IOS-Z80-MBC2.ino.with_bootloader_atmega32_16000000L.hex
The sketch for the IOS in executable format (.HEX) with the bootloader. This executable file is intended for use with a programmer as the Atmel Ice or AVRISPmkII or others (Fuse bits: High Byte 0xD6, Low Byte 0xAF, Lock Byte 0xCF)
x-hex - 59.90 kB - 09/24/2023 at 12:04
Download
SPP Adapter board - A240721-R270921.zip
All the documentation needed to build the SSP (Standard Parallel Port) Adapter board (A240721-R270921) including schematic, PCB assembling guide, Gerber files for PCB production. PCB is 55mm x 60mm 2-layers.
Zip Archive - 747.10 kB - 09/24/2023 at 15:10
Download
View all 13 files
  • 1 × See the file "A040618 BOM v2.ods" in the FILES section.
  • * * ​USING THE TASM CROSS ASSEMBLER * *
    Just4Fun10/09/2023 at 14:07 0 comments
    * * USING THE TASM CROSS ASSEMBLER * *
    The TASM cross assembler (Windows CLI application) can be used for various CPU. It can be downloaded from here. The on-line manual is here.
    Using the TASM cross assembler it is possible setup a toolchain to program the Z80-MBC2, doing all the development on a PC and uploading the code with the serial port and then executing it on the target Z80-MBC2 with iLoad.
    After the download of the TASM zip file, unzip it into your working directory (it is the folder where your assembler source files are stored) and to assemble an user source give the command:
    tasm -s -h -c -g0 -80  <Your_source.asm> out.hex
    It will be created the out.hex file (Intel-hex formatted executable file).
    Now you can upload and execute out.hex using the iLoad boot mode of the Z80-MBC2.
    Remember that iLoad will take the first address of the Intel-Hex stream as the starting address of the program, and after the loading will jump to it.
    At this point you can follow the same steps to create an automated toolchain described in the paragraph "SDCC: SETTING UP AN AUTOMATED TOOLCHAIN (WINDOWS)".
    TASM: USING AUTOBOOT
    If you want create a binary file to use with the Autoboot boot mode you can generate it with the command:
    tasm -s -h -c -g3 -80   <Your_source.asm> out.bin
    It will be created a flat binary file out.bin. Then rename out.bin as autoboot.bin and copy it into the root of the SD used by the Z80-MBC2.
  • * * ​USING THE SDCC CROSS COMPILER * *
    Just4Fun10/05/2023 at 13:27 0 comments
    * * USING THE SDCC CROSS COMPILER * *
    Using the SDCC (Small Device C Compiler) cross-compiler it is possible setup a toolchain to program the Z80-MBC2 with the C language, doing all the development on a PC and uploading the code with the serial port and then executing it on the target Z80-MBC2 with iLoad
    SDCC can be found here: https://sdcc.sourceforge.net/.
    After installing it, SDCC needs to be in some way instructed about how to deal with the specific HW of the Z80-MBC2.
    For this reason in the SD image, inside the \SDCC folder, there are two support files: S190818-R011023_crt0.s and S290923_Z80-MBC2.c.
    All the steps needed to configure the toolchain are explained below (we will assume a Windows operating system here, but the steps are similar for Linux):
    STEP 1:
    Copy the two support files S190818-R011023_crt0.s and S290923_Z80-MBC2.c from the SD image (\SDCC folder) to your working directory (it is the folder where your C source files are stored) and compile the first file with the command (from your working directory):
    sdasz80 -plosgff -o S190818-R011023_crt0.s
    It will be created the S190818-R011023_crt0.rel file.
    STEP 2:
    Now it's time to compile the second support file (S290923_Z80-MBC2.c). Here things are a little more complex because this file can be compiled in two different ways which differ depending on whether interrupts are enabled or not.
    The  need to have interrupts enabled or not depends on whether your user program uses them or not.
    To enable the interrupts support compile with the command (from your working directory):
    sdcc -c -mz80 -DZ80MBC2IRQ S290923_Z80-MBC2.c
    Instead to disable the interrupts support compile with (from your working directory):
    sdcc -c -mz80 S290923_Z80-MBC2.c
    It will be created the S290923_Z80-MBC2.rel file.
    STEP 3:
    iLoad uses the first address as starting address for the execution, so the executable file (Intel-Hex formatted) must be in ascending address order. This is not guaranteed by SDCC, so you need to use the srec_cat utility to sort the file. You can download this utility from here: https://srecord.sourceforge.net/  and then you have to copy the srec_cat.exe file into your working directory.
    All done!
    To compile your source file the command is (from your working directory):
    sdcc -mz80 --no-std-crt0 S190818-R011023_crt0.rel <your_source.c> S290923_Z80-MBC2.rel -o temp.hex
    It will be created the temp.hex file (Intel-hex formatted executable file).
    Now to sort the file give the command (from your working directory):
    srec_cat -disable-sequence-warnings temp.hex -Intel -o out.hex -Intel
    This will create the sorted file ready to be loaded with iLoad: out.hex.
    To create an automated toolchain you need another "ingredient", a terminal emulator supporting scripts. Here we will use Tera Term. You can download Tera Term from here: https://ttssh2.osdn.jp/index.html.en.
    After installing Tera Term, from the SD image inside the \SDCC folder, copy into the working directory the following batch files: SDC.BAT and L.BAT.
    Before using the L.BAT batch file you have to adapt two parameters according with the configuration of your PC.
    Go at line 18 and verify the path where Tera Term (ttermpro.exe) is installed, and at line 19 the number of the COM port used to connect the Z80-MBC2 to your PC.
    You need also to copy the Tera Term script LoadZ80.ttl from the /SDCC folder (inside the SD image) to the directory where Tera Term (ttermpro.exe) is installed, and adapt the parameter at line 15 with the complete path of your working directory in your system.
    Now to compile your_source.c file give the command (from your working directory):
    SDC your_source.c
    and to upload and execute it on the Z80-MBC2 (from your working directory):
    L
    Remember to close the Tera Term window...
View all 2 project logs
asorc wrote 03/04/2019 at 18:52 point
First time It started I selected basic... Then, It appeared memory top? message, and since then, when I press reset, It says cold or warm start? If I select cold, It becomes crazy, if I select warm, It says ok. I am confused.
Just4Fun wrote 03/04/2019 at 19:23 point
You must press "Return key" at "Memory top?" and then select cold...
asorc wrote 03/04/2019 at 15:44 point
Is It needed a vt 100 terminal to run the z80-mbc2? Or any serial monitor works the same?
Just4Fun wrote 03/04/2019 at 15:52 point
You can use any serial monitor. Some programs (video editors...) require a defined kind of monitor to work properly (generally they have a sort of config). Try and see...
asorc wrote 03/04/2019 at 18:45 point
Ok. Well... Something happened. I changed the baud option of the serial monitor of arduino ide, and It works for 9600 baud. Now, what's the different between cold and warm start? And What does "memory top?" means?
georgedb wrote 02/15/2019 at 11:07 point
Sorry, one more: can a 1N5819 be used instead of the 1N5817? When I look here [https://www.vishay.com/docs/88525/1n5817.pdf], I see slightly different parameters, and possibly the most important, slightly different forward voltages...
Just4Fun wrote 02/15/2019 at 12:20 point
I think yes...
georgedb wrote 02/15/2019 at 14:08 point
Will give it a try once I have received the components I don't have, and will report here.
georgedb wrote 02/15/2019 at 08:29 point
What a great project! I looked at the BOM, and there are quite a few components I already have. I tried to find (European) replacements for Q1/2 (2N2907), but failed. I guess this transistor is not critical in terms of parameters? Can any PNP transistor with the same pinning be used in this place, or are there specific parameters that play a role? And/or, does anybody know a good (European) replacement?
What I got in my parts bin: BC213, BC516, BC557, BC558, BC560C, ZTX213, ZTX550, ZTXC551
Just4Fun wrote 02/15/2019 at 08:46 point
Hi, you can use any "generic" PNP transistor. BC557 / BC558 will do the job...
-> NOTE: Check on the datasheet if they have the same pins placement!!! <-
georgedb wrote 02/15/2019 at 10:58 point
Perfect, thnx for your help! Always better to use what I already have ;-)
Linker3000 wrote 02/17/2019 at 22:34 point
I know you may not have them, but 2N3906 is a good replacement, has the same pinout and is easier to source; that's what I am using because I had some in my stock.
Peabody1929 wrote 02/12/2019 at 21:40 point
I built a second system.  It is up and running just fine with a HM628128ALP-7 SRAM as well.  To test the board I booted CP/M and ran MBASIC.  I opened the "Examples with Basic" on my PC, copied the USER LED BLINK example and pasted it into Tera Term at the MBASIC prompt.  This is a very easy way to get a program into the system.  Then I did SAVE "BLINK",A to put the app into the SD Card disk file.  RUN executed the app and blinked the LED.  All in all, it took about a minute the run the app to test the LED.  Very nice!
Linker3000 wrote 02/09/2019 at 13:55 point
Just FYI, the board works fine with HM628128ALP-7 SRAM and should also be OK with AS6C1008-55PCN.
asorc wrote 02/07/2019 at 16:15 point
Hello,
Let's see if some of you have had the same or a similar issue. So, I do not have a way to upload sketches in windows 7, but I do have a raspberry pi model b. Therefore, I use it to upload hex files to a blank atmega32a. I compile the sketches with the mightycore library, wire, etc. in windows 7, using arduino ide, and then take the hex files to burn them with the raspberry pi to the atmega32a using six wires and the GPIO connections of the raspberry pi. The result I get when I set up the computer to power it on and start the serial monitor of arduino ide, is that the IOS led starts to blink, but at a quite slow rate, and when I open the terminal, nothing happens. Has any of you had a similar problem? I uploaded a hex file that has the bootloader included according with its name, but I do not know if everything has gone really well, apparently avrdude tells me so, or if any IC is damaged. Thanks to all, in advance.
jmarik wrote 02/07/2019 at 21:16 point
Are the fuses set correctly? I used CF, D9.
asorc wrote 02/07/2019 at 22:24 point
I don't remember which ones come in the configuration of avrdude, because I have not touched anything else appart from the GPIO pins I use. I will have a look at it.
Linker3000 wrote 02/09/2019 at 14:09 point
Confirming the fuses (CF D9).
I ended up using a TL866 programmer because I could not get ICSP/USBASP to work. When I went back to basics later, I found that one of the wires in the ribbon cable I was using between the USBASP and the board header was open circuit! I only discovered this later when I could not get serial comms to work using the same cable! It's always the 'little things'!
asorc wrote 02/10/2019 at 01:01 point
Are these fuses the high and the low respectively? What about the lock byte?
I see there are different settings. I have seen the boards.txt of mightycore library, but It is not entirely clear to me which fuses It burns.
Frank N. Stein wrote 02/08/2019 at 09:00 point
I used "optiboot_flash_atmega32_UART0_115200_16000000L.hex" with
High Byte 0xD6
Low  Byte 0xAF
Lock Byte 0xCF
and it works very well...
asorc wrote 02/08/2019 at 12:48 point
Thanks for showing me where the problem is mostramos likely to be. I am checking the avrdude.conf file, in the m32 section, and I see some subsections memory lfuse, memory hfuse and memory lock, and below, without a write option, memory signature, memory calibration.
Definitely I have to get more knowledge. I guess these are some default values I can change there or externally, without modifying this. I have seen ways to do It with avrdude. I will have a look at it.
Thanks, any help is very very welcome.
Frank N. Stein wrote 02/06/2019 at 13:27 point
Hi, has anyone managed to send files with Kermit, Xmodem, Qterm or similar via the console interface? I have tried different versions of Kermit (with Terraterm on the PC side) that should have worked - unfortunately without success...
Z80-MBC2 does not support hardware handshaking, but Kermit should also work without it... :-(
Any help is appreciated!
RWDEANE wrote 02/12/2019 at 15:22 point
Currently there is  probably a bug in the z80mbc2 serial handling. An earlier message states that xmodem needs hw handshaking but this is untrue if configured correctly. Xmodem for RC2014 works by default without handshaking using console con: rather than more specific hardware access, I have used that on several flavours of rc2014 computer. I would expect the same version of xmodem to work on z80mbc2. Xmodem is expected to work to the same port that the serial terminal console is using (i.e. the one CON:)
Generic Kermit should work if the system bios supports IOBYTE (it does on rc2014) but I've never tried that on a one serial port system. It is possible that use of Kermit to con: would conflict with use on the same con: for the system console. If Z80MBC2 supported Xmodem and CPM BIOS IOBYTE then I would try Kermit to see how it behaves.
I believe Qterm makes too much detailed access to hw ports which are not virtualised in Z80MBC2 so Qterm cannot work. It may be possible that someone has made a more generic patch for Qterm, but again only worth considering when Xmodem is known to work.
It would really turn Z80MBC2 into an ace system if it supported Xmodem, currently that is blocking me from giving the system a higher star rating.
Michael Fong wrote 01/22/2019 at 07:43 point
vt100 card is a great addition.  If you're looking at doing another revision, I wonder if you'd consider some additional mounting holes at each corner of the card for horizontal mounting? Then you could mount it in a flat rectangular box.
Just4Fun wrote 01/22/2019 at 08:46 point
Hi, there are already two more holes for horizontal assembling... they aren't exactly on the corner, but a little more internal.
I'm "running" an other addition board, uCom (https://twitter.com/Just4Fun_J4Fun/status/1083675698412249089) that shares same dimension and holes position...
Michael Fong wrote 01/22/2019 at 11:31 point
Ooopppsss sorry didn't see them. Nice!  My friend and I really looking forward to building it.
Great work :-)
RWDEANE wrote 01/21/2019 at 21:48 point
I've just launched my Z80MBC2 with CPM3. I like it! I had a problem initially in getting the software into the atmega32 via serial or ISP. My serial didn't support DTR. Took me a while to figure out that I need to hold shift while starting upload in Arduino IDE via ISP, otherwise I just get another upload of MightyCore bootloader.
Now I'm looking for a version of XMODEM with generic CPM3 support of CON: so that I can upload and download files within CPM3 via the single serial connection. Does anyone know of an xmodem version that works for this?
Any chance of a Z80MBC3 design with a second serial port ?  :) And faster?
RWDEANE wrote 01/22/2019 at 08:08 point
I am told that the xmodem from the cpm section on foxhollow.ca (popular with RC2014) works unmodified on cpm3 but I cannot get it to work under  z80mbc2 with cpm3. Can anyone else get it to work? I've only tried so far under cpm3.
Just4Fun wrote 01/22/2019 at 08:48 point
Hmmm, I don't know... may be... it's too early to think about a  Z80-MBC3...
Frank N. Stein wrote 01/24/2019 at 13:59 point
First of all (@Fabio): MANY, MANY THANKS FOR THIS FANTASTIC PROJECT!
And then:
It looks like XMODEM needs a hardware flow control. (see "tera-term-serial-port.png" at Foxhollow) - ...and unfortunately this is not implemented in this Arduino! :-( In addition, RTS/CTS must be connected to the USB/RS232 converter and SJ2 must be shorted with a solderblob. )
I don't think we need a Z80-MBC3 for that...
An additional serial interface would be great! Would it be possible to use a SC16IS750 (or similar) on the I2C bus??
I LOVE MY LITTLE Z80-MBC2!!! :-)
Just4Fun wrote 01/25/2019 at 07:26 point
Thanks!
SC16IS750: Yes, but you need to modify accordingly the IOS FW and the OS (CP/M)...
RWDEANE wrote 02/12/2019 at 15:27 point
The right version of Xmodem does not require hardware handshaking, the version on foxhollow can work to con: and not require hardware handshaking. I use it on several flavours of rc2014 inc Bill Shen's ZZ80CF (see Retrobrew under Plasmo)
georgedb wrote 01/19/2019 at 11:19 point
Very cool, what a great project! Bought a PCB via an auction, now a scavenge hunt for the parts ;-)
I still got two (huge) 8" floppy disk drives, what would be needed to connect those (the 24V power supply has already been taken care of)?
A lot of Z80 info and other retro processors as well as some related projects can also be found on the website of Grant Searle. RC2014 is another website with interesting info on Z80 retro computing.
Just4Fun wrote 01/22/2019 at 08:50 point
There is no chance to connect a physical floppy disk, unless you design a proper controller and modify accordingly the IOS FW and the OS (CP/M)...
thumper109 wrote 01/19/2019 at 06:58 point
Just got mine working and I love it. Thanks for such a cool little Z80. Magic.
Just4Fun wrote 01/19/2019 at 08:30 point
Thanks so much! More has to come...  :)
Michael Jackson wrote 01/01/2019 at 17:14 point
Hi, I have three questions:
1. I've copied the content of the SD-S220718-R191018-v1.zip archive to the MicroSD card. This system boots up and I was able to change CP/M 2.2 to QP/M 2.71. But how can I change to CP/M 3.0? I don't know which disk image to choose.
2. Is there any tool like CPMTools for Linux? I don't have a Windows system here.
3. The blue User-LED is not lightning up on my board at any time, even when I press the User-Button. Is this correct?
Thanks again for this project! :)
yeti wrote 01/02/2019 at 06:17 point
@2: http://www.moria.de/~michael/cpmtools/ ... look if your distribution already has it.
Michael Jackson wrote 01/02/2019 at 11:35 point
Thank you! My question was really unnecessary. The official Linux Mint repository has the "cpmtools" included.
Just4Fun wrote 01/02/2019 at 08:43 point
@1: Enter into the "select boot mode..." menu, press 8 and then press any key (not ESC)  repeatedly until you select the wanted OS, then press CR to activate.
@3: Try USERLED.BAS example.
Michael Jackson wrote 01/02/2019 at 11:42 point
@1: OK this was much easier than I've imagined. Thank you, this works! :D
@3: Although I've listed the disk image files and seen the USERLED.BAS I haven't tried it till now. I've started it and it tells me the LED is blinking but it isn't. I will solder another one on the board maybe it was broken before I've soldered it. Thanks again!
Just4Fun wrote 01/02/2019 at 11:52 point
@3: check the led polarity too...
frank maertin wrote 12/21/2018 at 20:47 point
Got  my 5  pcb's today. Does anybody needs one?
Shipping only to Germany. 1 Toshiba RAM, ATMEGA and Z80 are also avialable, if needed.
SupraJames wrote 11/25/2018 at 22:05 point
Just want to share something I’ve found tonight. I had an ESP8266 module in my collection and using esp-link (https://github.com/jeelabs/esp-link) my Z80-MBC2 is on my wireless network and I can play with it from anywhere using telnet - and even remotely reset the board and re flash the Arduino part via a web page. It’s beyond cool! Just connected the ESP8266 instead of the USB serial module.
villaromba wrote 11/26/2018 at 09:58 point
Interesting concept, had a read on jeelabs and thought I would give it a go. The ESP8266 is only a few dollars from Aliexpress as well - so well affordable !!!
citizen38 wrote 10/27/2019 at 16:43 point
Hi James, how are you managing the remote reset function? I'm using esp-link for serial comms already. Is it a DTR function?
Just4Fun wrote 11/25/2018 at 10:12 point
Thanks guys..!
BTW: Currently I'm "playing" with a new "thing":
https://www.retrobrewcomputers.org/forum/index.php?t=msg&th=223&goto=560555&#msg_5605
Stay tuned.... :)
John wrote 11/23/2018 at 22:15 point
Thank for a great project. Been wanting to run CP/M on a real Z80 now i have it :)
Regards
Jman
asorc wrote 11/23/2018 at 20:28 point
Hello,
I ordered 5 pcbs and I've received them today. I am looking at the layout guide, and I have a question about the legend which says 10 k 8. What does it mean? What's that? I've read something about SIP. But I do not know what's that. Could anyone help me? Thanks a lot  in advance.
villaromba wrote 11/23/2018 at 20:58 point
You'll find in the Bill of Materials (In Files section) the parts list.
The SIP used is 8 x 10k resistors in a Single Inline Package (SIP) with a common pin for all 8 resistors making 9 pins in total. They are also called a Resistor Array Network.
Jeff Davis wrote 11/24/2018 at 02:14 point
I made a google docs BOM with corrections and longer item descriptions: https://drive.google.com/open?id=145w-IAsDimTIEjg6kTirIJTWtZTU7UPEflaH5Kcza1Q
asorc wrote 11/24/2018 at 13:33 point
Thanks a lot. I've read about resistors array later on. I do not have much knowledge... Btw, I have around 1n5819 instead of 1n5817, and 2n3906 instead of 2n2907. Could I use them?
Just4Fun wrote 11/25/2018 at 10:06 point
Yes, you can do it for both the components. The 2N3906 must be in TO-92 package, so the pins are in the right place...
SupraJames wrote 11/23/2018 at 17:21 point
I am pleased to show my first proper Z80 assembler program. It's a memory tester, which might be useful in the homebrew world. It does bank switching so we can test almost all the 128k which the Z80-MBC2 has, except for the little area where the program runs!
Just paste the .hex into iLoad to give it a go, or look at the source.
Comments? https://github.com/SupraJames/z80-mbc2
villaromba wrote 11/23/2018 at 22:11 point
Nice one, just ran a quick mem test - perfect!! Will check out monitor late weekend ....
SupraJames wrote 11/13/2018 at 21:51 point
i noticed that the old MBC was using the serial port at 38400 baud but the new one is 9600 only. Is there a technical reason for that?
Jeff Davis wrote 11/14/2018 at 08:47 point
I changed the avr ios program's serial from 9600 to 38400, compiled and uploaded to the avr, and it seems to run just fine (played startrek), which makes sense since the serial port is handled by the avr cpu. 9600 just feels more retro I think since the terminal draws a lot faster at 38400.
