1Lettuce Begin
It was a dark and stormy night (not really) in winter 2013 and I was in the produce section staring at some particularly bad lettuce. Wilted would have been a kind description. "There's got to be a better way!" I thought. I had always been interested hydroponics, growing plants in water without soil, and figured I could easily grow lettuce better than THAT.
Researching existing hydroponic systems, I found they were bulky and expensive. Being a typical engineer, I figured I could make something better/faster/cheaper. How hard could it be? I determined that the most advanced systems use aeroponics, which sprays the roots with a fine mist. Wanting to be at the forefront indoor agriculture, I began designing my own aeroponics system.
The picture below should give you an idea how the system works. Looking through a plant port in the side of a tower pod, it shows the roots after the lettuce has been growing for about 6 weeks. The round object at the top of the frame is a mist sprayer. The black square in the middle is one of the foam plant holders coming through the side of the pod. The water drains through the stacked pods from top to bottom, and anything not absorbed by the roots ends up back in the bucket.
2How it Stacks Up
The picture below shows the main portion of a three pod test system. The pods are separated from eachother and from the base with four vertical links. These minimize the amount of plastic and thus 3D printing time/cost to get the desired vertical spacing. From top to bottom the tower has the following:
- Pressure Gauge
- Plant Starter Area
- Plant Pod A
- Plant Pod B
- Plant Pod C
- PVC Pipe Mounting Adapter
- PVC Pipe Base with Computer and Pump
- 200 Mesh Stainless Steel Water Filter
- Water Reservoir
- Pipe Base Aligner (inside the bucket)
3Keep Your Plants On
Plants need something to support them while they grow. Many hydroponic systems use foam since it can expand as the plant grows. The LGT uses reticulated foam, which is a special type of open cell foam. Open cell foam has open walls between all of the bubbles that make up the foam. It is much more breathable than closed cell foam.
In the first PVC pipe based version of the system, the foam was cut using the die in the picture below. It produces a 2" cylinder with an "X" and hole in the center. The hole is filled with carbonized bamboo fiber that extends beyond the foam, as shown in the second picture. The fiber wicks moisture from inside the pod to the seeds when they are first planted. Once I decided that the system could be 3D printed, I changed to square holes in order to avoid foam waste after cutting. In this case, the same die is used with pre-cut square blocks, but only the "X" and hole portion in the center is cut.
The foam is held in place by a 3D printed square collar as shown below. A child-size silicone wrist bracelet provides a gasket between the plastic holder and the pod. The picture in section 1 above shows an interior view of the plant holder where you can see the gasket. -
4Baby Steps
5Getting all Misty
Some aeroponics systems use nozzles that produce more of a stream than mist. Others use expensive nozzles that require high pressure and produce a very fine mist. The 30PFAF008-80 nozzles are a good compromise in price, performance, availability, and ease of replacement.
6Go with the Flow
To RV or not RV, that is the question. Actually, it really was not that much of a question. After trying lots of cheap, noisy pumps, I decided the best solution was a standard 12V RV water pump. RV water pumps are durable, widely available, and there are even repair kits for when the diaphragms wear out. The pump is one of the most expensive components in the system, but it is also one of the most important. It does not pay to cheap out on a pump and have your system fail unexpectedly.
The picture below shows the LGT pump, a SHURFLO 4008-101-E65 . The pump comes from the factory with a rubber shock mount, but that is removed and the shock mount screws are used to hang the pump from the column on a 3D printed bracket. This allows the pump to be lifted out of the bucket at the same time as the rest of the column when the column is moved to a second bucket to change the water.
A possible additional benefit of hanging the pump on the column is that it vibrates the column when it runs. Some studies have shown that vibrating the root system of plants enhances growth.
7The Bucket List
In order to minimize cost and maximize ease of use, the system uses standard FDA food contact approved 3.5 gallon buckets. These are filled with about 10L of nutrient solution, leaving enough space at the top so that the bucket can be carried without spilling. The built in handle makes them relatively easy to move, especially when full of water.
The green color is used to minimize the amount of light seen by the nutrient solution in order to minimize algae growth. While black would have been best in this respect, I was worried that it might absorb too much light and warm up the nutrient solution. Plus, green matches the plants :-) . White would have been best to minimize absorption, but it is lets too much light through.
One nice thing about buckets is that they are stackable. When shipping a system, two buckets don't take up much more space than one. Having two buckets makes changing the water very easy. Just mix up a new bucket of nutrients, pull the column from the existing bucket, place it temporarily on a column stand so that it doesn't fall over, replace the old bucket with the new bucket, and place the column in the new bucket. I actually haven't designed a stand yet, I just balance the column very carefully. Eventually there will be a stand.Other tower systems have huge immobile water reservoirs. I'm not sure what their water changing procedure is. For the LGT, it's relatively easy to move the approximate 25 lbs/12Kg of bucket and water. I actually haven't weighed the column, but it feels like it's in the same weight range. After swapping the buckets, the old nutrient solution can be user to fertilize outdoor plants or grass.
In order to minimize light intrusion and evaporation, the top of the bucket needs to be cut for a very close fit to the column. A 6-3/8" ceiling light hole saw is a good fit and provides just enough space for a rubber gasket around the inside rim.
Additional holes must be drilled for the water filter, the conductivity probe, and the PH probe. The exact dimensions of these holes has not been finalized. -
8Column Advice
This section will describe how a piece of standard 4" PVC pipe is used for the base of the tower
9Mod Pods
This section will describe the plant pods
10Outer Tubes
This section will describe the simple push-lock fittings used to bring the water from the pump to the sprayers
Thanks, I prefer a bit of cheese with my salad :-)
Nice titles ;)
