Hackaday.io Hackaday.io
Sign up Log in
Camera DRO
Using a webcam and OpenCV to replicate a Milling Machine Digital Read Out (DRO).
maxbareissMaxBareiss
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
8 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
359
0
8
6
Team (1)
  • maxbareissMaxBareiss
Join this project's team
  • Source Code
Software
ongoing project
opencv machining
This project was created on 07/28/2018 and last updated 7 years ago.
Description
Milling machine Digital Read Outs (DROs) are expensive pieces of equipment that measure the position of the milling machine table. This allows the machine operator to line up features with each other on a part and put them precise distances away from each other. Without a DRO, using a milling machine is difficult and some operations aren't really possible. Things like bolt patterns are pretty easy to do with a DRO but without a DRO you'd need a rotary table, which is expensive.
The idea here is to use Charuco boards to locate the milling machine table. Charuco boards are paper and are cheap. Webcams are readily available. DROs usually cost around $400, this setup was made with parts I had sitting around.
Components
  • 1 × PS3 Eye Webcam
Project Logs
Collapse
  • Camera DRO Initial Testing
    MaxBareiss • 07/28/2018 at 18:38 • 0 comments
    Today the code was created and initial testing was done.
    TLDR
    Absolute accuracy of Camera DRO is about 2 thousandths. Relative accuracy is similar. This is way better than I expected.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Fixing up vintage sewing machines for hobby use.
Project Owner Contributor
Vintage sewing machines
joseph-eoffJoseph Eoff
To create a crazy Rube Goldberg/Wallace & Gromit/MacGyver machine that will automatically clean the mold from floppy disks.
Crazy Disco Floppy Disk Cleaning Machine
rob-smithRob Smith
Describes my experiences buying, setting up, and using the SMT50 pick and place machine
SMT50 pick-and-place
tim-wilkinsonTim Wilkinson
I bought a 1965 Singer 338 as my first machine to tinker with.
Extending the Range of a Singer 338
kristina-panoskristina panos
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Camera DRO", please tell us the reason.
Send message
Remove Member
