1Prepare the pipe segments
Cut the pipes into pieces of required lengths. If pipes are available in 10 foot spans, you will require 2.5 full length pieces. Assemble the frame.
2Prepare the PVC Wire casing
Cut the PVC Wire casing into required lengths.
3Attach bulb holders
On one of the mating halves of the casing, drill 3 holes at equal lengths. Wire up the bulb holders, passing wires through the holes. Screw bulb holders in place. Repeat for all 4 modules.
4Make snap-on segments
5Wiring up
Complete wiring up the bulb holders, switches and plugs for every module. Create a combined plug-point by wiring up 4 female 2-pin sockets with a suitable length of wire into a single plug.
6Final Assembly
Snap the modules onto the frame, insert bulbs into the sockets and plug everything in after checking for loose connections, etc.
