Radiant Heat Device for Filariasis Therapy
DIY-able heat therapy for helping with Filariasis symptoms at home
Public Chat
0 followers
(I initially worked on this project way back in 2009-ish, and while it achieved what I initially set out to do, there is a lot of scope for improvement. Besides, it was always meant to be open-source.)
Thermal therapy – application of heat – is recommended to Filariasis patients for therapy and relief. This is required frequently and often, especially as Filariasis can flare up recurrently once acquired. Currently available devices have several issues including accessibility and cost.
This is a low-end DIY-able home-based solution which the patient can DIY/get fabricated and use without traveling or time constraints.
A PVC-pipe based frame that uses T and L joints to allow it to be collapsible forms the main structure. I used segments of PVC wire casing to mount the bulbs and run the wiring, as well as make the bulb-assembly easy to snap on and snap off.
The device is functional and easy to fabricate, but there's room for improvements.
Basic Principle of Treatment :
The affected limb(s) are exposed to the radiant heat from the tungsten bulb arrays. The duration is based on the doctor's recommendations and patient's comfort.
Issues with current devices in the market :
Radiant heat device
The device currently used is quite heavy and cumbersome to deploy
- Cost
- Size and weight
- Available only in hospitals/medical centres, due to cost and size
- Accessibility; patients should ideally be using these frequently but having to travel to a hospital means they use the service far less than recommended. Due to the large number of patients, available time per patient is also limited. Besides, traveling while suffering from the condition is not recommended.
- Usability; even at the hospital, the attendants find the device quite large and cumbersome to unload and deploy.
Requirements :
- low cost
- lightweight
- small footprint/easy storage for home use
- simple and low-cost fabrication, avoiding specialized components and tools
Concept :
A. The Frame :
The frame is made of PVC pipe segments. A combination of T and elbow joints is used to create a pivot joint that allows the frame to be flattened and put away when not in use.
PVC pipe frame with T and elbow joints
The PVC pipe frame in various stages of being folded up
B. The Bulb arrays :
The bulb arrays are bulbs in holders screwed on to PVC Wire Casings. There are two modules along the upper face of the frame (3 bulbs each), and one each on each side (2 bulbs each). The wires run through the wire casing.
The PVC casings are two mating pieces that slide along/snap into each other. Square end pieces of one mate are cut off and screwed into the pipes. These act as snap-on holders for each bulb-array.
Each holder is wired in parallel to the others on its module, with a switch at the end, ending in a 2 pin plug.
C. Heat Conservation :
While in use, for more effective treatment, the heat can be contained or regulated by draping a thick wool blanket over the frame, trapping the heat underneath.
Usage :
A. Deployment :
  1. The patient or a care-giver pivots the frame open.
  2. The 4 bulb modules are snapped onto the frame, and bulbs are inserted if removed for storage.
  3. The bulb modules are plugged in and switched on.
B. Usage :
  1. The patient lies underneath the frame receiving the radiant heat on affected limbs for as long as recommended.
  2. A blanket is draped over the frame to conserve the heat.
Benefits :
Low Cost : The entire device should come to about Rs. 1000 of material costs.
Ease of fabrication : It should take a couple of hours to fabricate and assemble for the first time. It can be done by almost anyone - caregiver or patient - with a basic skillset and tools, or failing that, the local electrician/carpenter/handyman/fabricator.
Lightweight : Being PVC, as well as modular construction, the device is  lightweight.
Easy storage : Since the bulb module comes off and the frame flattens up, it can be stored easily in the home. The bulbs can be removed from the modules as well.
Design Considerations :
PVC pipes are inexpensive, strong and ubiquitously available. The other structural option was aluminum channels, but the risk or short circuits from a loose connection were too high.
PVC wire casings offer a built-in snap-fit structure, so no external components are needed to enable a quick release mechanism. Also inexpensive and ubiquitous.
Beyond the overall sizing, the dimensions have been left open to suit locally available components and choice of build materials.
  • 3 × PVC Pipe 3/4" diameter - 875 mm
  • 4 × PVC Pipe 3/4" diameter - 750 mm 750 mm
  • 6 × T joint for PVC Pipe 3/4" | 18 mm diameter
  • 4 × PVC Wire casings 800 mm
  • 10 × Bulb holders
View all 13 components
  • 1
    Prepare the pipe segments
    Cut the pipes into pieces of required lengths. If pipes are available in 10 foot spans, you will require 2.5 full length pieces. Assemble the frame.
  • 2
    Prepare the PVC Wire casing
    Cut the PVC Wire casing into required lengths.
  • 3
    Attach bulb holders
    On one of the mating halves of the casing, drill 3 holes at equal lengths. Wire up the bulb holders, passing wires through the holes. Screw bulb holders in place. Repeat for all 4 modules.
View all 6 instructions
