miniSolar Charger
A solar powered, battery buffered, USB charger.
Don't let its size fool you! This circuit accepts a solar panel up to 5 Watts to charge a li-ion battery cell, then can charge a USB device at 1 A. It performs Maximum Power Point Tracking with its synchronous buck converter to obtain 90% charging efficiency, then powers the USB port with the Microchip MIC2876, providing up to 95% output efficiency.
All of this is controlled by pushing a PIC12F1571 (8 bit, 5 gpio, 128 bytes RAM, 1k words flash) to its absolute limit.
Functional Description
The circuit in this project contains two power circuits. The first is a synchronous buck converter, controlled by a microcontroller carrying out MPPT, to send power from a 2 watt, 6 volt solar panel into a small lithium battery cell. The second is a boost converter that provides 5 volts for USB charging from the lithium cell.
Normally, this small of solar panel would be inefficient and unreliable when charging USB, as the power available and the power requested would never match. The battery buffer fixes this: excess solar charges the battery, excess demand drains the battery. In the case where the demand continuously exceeds supply, the output can be shut off temporarily while the battery charges back up again.
A bare-bones microcontroller, the PIC12, provides control for this project. It measures current and battery voltage, then controls the MPPT and can turn the output on or off. There is also a bright white LED that serves double duty as an indicator and a flashlight. Lastly, a small button engages the indicator/flashlight. All of these functions are done with very strategic allocation of the extremely limited resources of the microcontroller.
The circuit and battery are placed in a 3-D printed enclosure, which also includes a phone sleeve and a housing for the solar panel. The result is a portable little box that should be able to keep a phone charged indefinitely during outdoor activity.
Objectives and Specs
The objectives for this project are low cost, small size, and high efficiency. The PCB components total about $9 in single quantity. The total material cost, including components, PCB, battery, and solar panel, is about $20.
The dimensions of the PCB are 1.00 x 0.66 inches.
The efficiency of the solar to battery buck converter was measured to be roughly 90%. The efficiency of the battery to USB boost converter is listed in the datasheet to be up to 95%.
The input power is limited by the size of the inductor; its current rating is 1.75 A. With a (worst case) battery voltage of 3.0 V, this restricts the solar panel to 5 W or less. A 6V (12 cell) panel is needed to consistently exceed the battery cell voltage. The solar panel's open-circuit voltage must not exceed 20 V to avoid damaging the circuit, but a 12 V (24 cell) panel should work.
The battery cell needs to be Li-Ion chemistry and capable of discharging at 2 A and charging at the solar panel maximum power. Otherwise, capacity is irrelevant. A small quadcopter battery works well to reduce weight.
The USB output circuit can technically deliver 3.8 A, but with no power negotiation circuit on the USB port, every device I've seen will draw no more than 1 A.
Renderings
Top Render
Top Render
Bottom Render
Bottom Render
Front Render
Front Render
Demonstration
Here's the device working next to the window in my kitchen. I opened the charger to show its charge current, and put a USB meter on its output. The sunlight is coming through a window in the Minnesota autumn, so it isn't very intense, but enough to show some charging. Meanwhile, the circuit is charging up a USB battery.
When this photo was taken, there's 127.3 mA input current at ~6 Volts, so roughly 0.75 Watts coming from the solar panel. Meanwhile, the USB battery is taking 0.33 A at 4.81 V, or 1.59 Watts. Neglecting losses, the net power of 0.84 Watts is being drawn from the charger's internal battery.
Assuming this power remains constant, in about 90 minutes the charger's battery will get low and it will cut power to the USB port. It will then charge its battery off the 0.75 W of solar power until the battery is high again - another 90 minutes or so. The USB port will be re-enabled, and the cycle will continue until the sun goes down or the USB battery is filled.
minisolar.X.zip
Firmware files for MPLAB X, as of 9/2/18
x-zip-compressed - 280.50 kB - 09/02/2018 at 17:42
Download
Simple_Solar_Charger_Gerber.Zip
Gerber files for the second version, generated in Altium CircuitMaker. Also includes the drill file.
x-zip-compressed - 44.58 kB - 08/19/2018 at 14:39
Download
View all 9 components
  • Possibly the Final Update
    Peter Thompson09/15/2018 at 13:23 0 comments
    The mini Solar charger has gone well and I think I'm ready to move on to my next project.
    The past week I've been tackling problems with the battery draining too quickly when the device is not in use. Changing the code to run in sleep mode seems to have fixed this pretty well, and now I expect the battery to last a bit over a month in total darkness. The main cause of discharge now is backflow through the solar panel, which I measure at 0.6 mA. Adding a diode would fix this, but lob off a good chunk of efficiency (a good Shottkey diode would cut about 10% off).
    Messy discharge measuring setup.
    The circuit is working just as I expect it to, but the solar panel is underwhelming. I knew going in that 2 watts is pretty minimal, and you usually get much less than that.
    I also might put more thought into the enclosure. It fits pretty well; overall I'm happy with it. It's not totally sealed but could probably take a splash. The phone slides in and out okay, and the top flap keeps it tucked in. You can see in the picture that the sun has discolored the filament, but I haven't noticed any other property changes.
    I do have a bit of a heating issue. When charging an iphone with it inside the pocket, the phone overheated to the point where it refused to charge. The solar panel gets pretty warm in the sun, and with this design, that heat transfers right through.
    I might ditch the pocket idea altogether; the user probably already has a more secure place for their phone.
    That's all for now. I'm going to go back and update my documentation, get a few action shots, performance specs, etc.
  • Efficiency Testing
    Peter Thompson08/31/2018 at 14:11 0 comments
    If you don't feel like reading this: 90% efficiency, with some unfortunately large error bars.
    I finished putting together the Rev 2 prototype, tweaked the firmware a little, and it works! Both the input and output converters are doing their job, power points are tracked, the LED does exactly what I want it to.
    I wanted to put together the whole thing and mark the project as complete, but there's one more thing I need to test:
    Was all of this worth it?
    I added a buck converter with MPPT to this circuit on the belief that I would get more energy from that than simply connecting the solar panel to the battery. And while I picked out efficient parts, I didn't have a good way of estimating the efficiency of the build before putting it together.
    Therefore, today's lesson: How to measure efficiency.
    Recipe for Power Efficiency Measurement
    Ingredients:
    • A 4-channel oscilloscope
    • 2 Precision low-value resistors
    • An appropriate power supply
    • An appropriate load
    • A converter to test
    Step 1: Preparing the ingrediants
    Rigol. No surprises there. First time I've gotten to use all four channels though.
    I dug around my parts bin and found these bad boys:
    Oops, did you say precision? I thought you said +/- 10%.
    We can fix this. Power supply + DMM + Scope = Precision resistance measurement.
    Input current resistor: 5.06 Amps of current generates 0.988 V -> 0.195 Ohm. Well outside even the loose tolerance specified. I double-check all my connections; either my instruments are way off or this resistor is. I'd like to trust my instruments, while these resistors are many decades old. I'll take the measurement as fact.
    Output current resistor: 5.06 Amps generates 0.946 V -> 0.187 Ohm.
    Home made! And crappy! But it does the job, even if I can't really control the current and the current measurement is off by nearly a factor of 2. I built it based on this: https://www.thingiverse.com/thing:2085223
    Since my converter expects a solar panel as an input, I add a 33 ohm series resistor out of the power supply. That way, it has a well-defined maximum power point at 1/2 the source voltage.
    My converter expects to charge a battery, so this little lithium cell is my load. It's different from what I intend to use in the final device, but it has some on-board protection, which will be good when I accidentally short this thing out.
    Right here on my desk. Did I mention it's small?
    Step 2: Setup
    In order to measure efficiency, we need to measure the input power and output power, as your standard efficiency formula shows:
    To get electrical power, we need voltage and current, according to P = V * I. So our formula is:
    Problem with this is that I can't measure current with my oscilloscope. I can with the DMM, but I only have one of those. This is where the "precision" resistors come in. By measuring voltage on each side of a known-value resistor, I can calculate the current running through it. Therefore, I want to set up my circuit like this:
    Note from the future: This won't work; don't do this. I'll find that out later.
    By substituting my voltages and currents with the values I measure and calculate, I arrive at the following:
    It's not the prettiest thing wired up:
    Step 3: Run (away)
    For this test I'm going to use my standard code. Battery level is 3.8 Volts, switching frequency 40 kHz. I'll shoot for about 100 mA input current. We'll fire up the power supply, wait for things to level out, and take a capture of the data. The math functions on this scope aren't sufficient to carry out the formula above, so I'll import the raw data to MATLAB.
    I take the data onto a USB drive, load it up in MATLAB, and do a little this:
    >> mean((CH3 .* (CH3-CH4)/0.187)./(CH2 .* (CH1-CH2)/0.195))
  • Rev 2
    Peter Thompson08/28/2018 at 02:26 0 comments
    Second revision boards arrived today. Probably the nicest part of this project is how cheap I can get 5-day-lead PCBs from OSH Park.
    Here's how Rev 2 (middle) measures up compared to Rev 1 (above) and my PCB ruler (below):
    And, for perspective, the assembled PCB in my hand:
    Lastly, I've been working on the enclosure some more. I've been having a bit of trouble printing with the flexible filament. I learned that hard way if your print head is calibrated too close to the bed, normal filament will over-extrude, but flexible filament will simply jam up. I have that sorted out, but now I'm finding that flexible filament is nearly unworkable with support and bridging. Below is Rev 2 of the enclosure, before cleaning.
    I might have to get creative. If only I had a multi-material printer, eh?
    Oh well. I'll find a way to clean up the enclosure, get the Rev 2 board working, and then I should be pretty much done!
  • Version 2
    Peter Thompson08/18/2018 at 23:37 0 comments
    I'm ready to send out the second revision. It looks like this:
    That's .66 square inches of handsomely packed parts.
    Besides the mechanical reconfiguration, I put on a bigger inductor, and pushbutton, fixed some of my footprints, added a little capacitance, improved the microcontroller pinout, and added some filtering on the current sensor.
  • Update: Circuit Working
    Peter Thompson08/13/2018 at 23:18 0 comments
    Got it up and running! After a good day's work fixing my soldering, writing some test software, debugging, scoping, etc. I have a working circuit board and very basic firmware.
    And...it looks like this now:
    So... the inductor. Obviously this isn't what I had in mind. I guess I was too excited to get a board ordered to actually calculate the inductance I needed in the buck converter. My original was a 1 uH inductor. This is what was called out for the boost module, so I figured the buck had similar needs and could use the same inductor.
    Which is obviously wrong. The boost module has a switching frequency in the megahertz, where the highest I can get the microcontroller to do is 320 kHz (160 kHz if I need 100 steps of PWM).
    So I scrounged and found the big through-hole inductor shown, and got that to work.
    In other news, turns out I misinterpreted the rules for the one-square-inch challenge (or they changed the rules all the sudden?). They want the entire board to fit, including the components. This doesn't fare well for my big USB-A connector hanging off the edge of the board.
    The USB connector needs to be there; it'd be stupid to not have it, given the board's intent is to be a USB charger. I could move it off the board, but that's not a clean solution. I have enough flying leads already.
    So how to fit the connector within my square inch? My first thought was a vertical connector, but that makes the positioning awkward. So I think the solution is to switch to a surface-mount connector and put it on the back of the board. This makes the board thicker, but I think it'll work if I keep all the big parts on the bottom.
    I'm a little upset that I have to redo much of the layout to make this work, but I guess they call it a "challenge" for a reason. And I have to redo a good chunk of it to fix my footprints and get a bigger inductor on there. Maybe I'll even have space for some more input capacitance.
    Anyway, I should have enough time for a respin.  Next step is finishing up the firmware, doing some testing, then I can respin and get a nice final product.
    And speaking of firmware:
    80% data memory usage already? (tugs collar nervously) I can safely say I've never pushed a microcontroller this close to its limits.
  • Woops...
    Peter Thompson08/11/2018 at 17:25 0 comments
    I quickly found the first issue with my PCB. I have to admit, this was a pretty stupid mistake.
    Note the numbering order. It's clockwise, but should be counter-clockwise. This means pins 1 and 3 are swapped, as are pins 4 and 6. What I was thinking when I thought the numbering should be clockwise is beyond me. I assume I was looking at a drawing of the underside of the part when I was doing the pin order.
    At first I thought that was it. There's no way I could fix a layout that tiny, I'd have to reorder the board. But, with some really careful cut and rewire, I managed to do the pin swapping and verify that all the new connections were good. Felt like a freaking superhero when I finished, too.
    See part is in the bottom-center. It's certainly not ideal, but besides the excess flux the repair is barely visible and should hold up. Hopefully the tiny wires I had to use won't add too much resistance.
    Hopefully the rest of the assembly goes more smoothly.
  • Mechanical Design
    Peter Thompson08/10/2018 at 22:51 0 comments
    While I wait for my boards to be delivered, I spent some time working on the mechanicals. I've been 3-D printing for a couple years now, but this project made me want to try something new: Flexible Filament. I ordered some green TPU from a brand called Priline.
    I designed this as sort of a phone pocket, with extra width so that the front would fit the solar panel. Some space is cut out of the sides for the battery and charger circuit.
    I designed this in Fusion 360. Here's a link to the design: https://a360.co/2MyXXA5
    Here it is after a couple revisions:
    One problem that I came to a neat solution on: sealing in the battery and charger. Eventually I got the idea of using the solar panel itself to close up the "box" that the other parts go in. This saves material (weight) and makes everything a lot simpler.
    I printed out an early revision to test the fitting. Most of it is encouraging, but I found a lot of things to change. Printing with flexy filament went pretty well once I dialed in the heat settings (reducing the print bed temperature did wonders). But, as expected, the stuff doesn't bridge well, so a part like this takes a quality hit.
    Here are my parts layed out...
    And assembled...
    My PCBs just arrived from OSH Park. They look like they might be a little tricky to solder, but I'm up for a challenge. These are the first revision boards that have a length just a hair over one inch, though I already designed a revision that fits in a one inch square. Next up: build and test this thing.
  • Project Design
    Peter Thompson08/07/2018 at 19:10 0 comments
    Theory of operation:
    The miniSolar is designed to take in power from a 2-3 watt solar panel, charge a small lithium battery, and charge a device. Since USB devices tend to draw a constant current, the battery buffer is required to supplement the solar power when it's insufficient to charge the device by itself. This has the additional benefit of allowing the solar panel operate at full efficiency to charge the battery when the load is low.
    A microcontroller is used to run the converter with Maximum Power Point Tracking (MPPT). It also contains logic that can enable or disable the USB output, preserving the battery and allowing intermittent operation when the solar input is lower than the demanded load.
    The intended mechanical configuration is to build a "pocket", with the solar panel as one side, the electronics at the bottom, and space inside for a phone or other device. This way the miniSolar doubles as a phone protector.
    Circuit Design:
    At 21 components, this is definitely one of my simpler designs.
    This circuit contains:
    • A PIC12 microcontroller, with 8 pins. This little guy is pushed to its limit, with some pins getting multiple uses!
    • A programming header for the PIC
    • A button and LED. Since I'm short on pins, these guys have to share, with the side effect that pushing the button will turn on the LED. The LED is to double as a make-shift flashlight.
    • A 5V boost converter IC. In the spirit of "keep it simple", I let an IC do the work of generating 5 V from the battery.
    • A custom synchronous buck converter. This is easily the trickiest part. I intend to implement MPPT, so measuring the current from the converter is a must. Due to the low voltages/powers involved, a boot-strap high-side NFET driver was deemed infeasible. Therefore, a PFET is used for the high-side gate, sacrificing low on-resistance for simpler and more efficient gate drivers.
    PCB Design
    I designed the circuit and PCB in Altium CircuitMaker, my hobby tool of choice. I hold Altium as the gold standard of user interface, and once you've gotten used to it it's hard to use anything else.
    The first prototype is just slightly over the One Square Inch requirements at 1.1 inch, which helps the USB port have more mechanical support. I cut it down a touch to fit the rules of the competition, and now the dimensions are 1.000 by 0.665 inches.
    This is a two layer board with all the components on one side (except the button, which is on the back so that it's reachable). This circuit has a job to do, so no frills or fancy art, yet CircuitMaker renders it beautifully.
    This CircuitMaker project can be accessed at https://workspace.circuitmaker.com/Projects/Details/Peter-Thompson-3/Simple-Solar-Charger
    Next Steps
    OSH Park just notified me that the boards are back from the fab! In a few days, I'll be able to build this up and test it out. I have a bit of code to write and an enclosure to draw up as well.
View all 8 project logs
