Drag-n-Drop FPGA Loading
06/01/2024 at 03:22 • 0 commentsIt is now possible to drag-n-drop an image onto an Altera FPGA.
This project has taken many detours, often due to a lack of time for software development (or my preference for circuit-board design). In any case the latest detour came when I learned about the PICO-DIRTYJTAG project by Patrick Dussud. This project enables the $4 Raspberry Pi RP2040 Pico board to work with openFPGALoader to program a wide variety of FPGAs. This would save me quite a bit of time with software development, or so I thought.
Getting PICO-DIRTYJTAG working with openFPGALoader was a breeze. My first test was to load an image into the MAX10 10M08 Evaluation Kit that does not include an integrated loader. openFPGALoader "supports" MAX10 through SVF files, which technically works, but is painfully slow. So slow that I decided to find a better software solution. I had stalled on my previous efforts to implement an SVF interpreter and decided to look for some other options. Altera also provides STAPL JAM and JBC files for programming, and these are a little more embedded friendly. JBC files convert JAM files to byte code and are more space efficient, so I opted to implement a JBC loader.
Contrary to some pages on the Intel website, the JAM and JBC player code has NOT been discontinued. You can still find it if you know where to look. I downloaded the code and started porting to the RP2040 Pico board.
Unlike an SVF file that must run linearly, JAM files have advanced features such as looping that requires the ability to go back in the file. This means that you can't simply stream through it, but you need to store it. The Pico board does not have enough RAM to hold a JBC file, but fortunately the flash is large enough to easily hold the full image for a small device like the 10M08.
The Raspberry Pi RP2040 includes a UF2 based bootloader for firmware updates. This makes loading images a breeze. No drivers or tools are needed to load the firmware because it appears like a USB drive that most operating systems recognize.
One way to get the JBC image into flash would be to build it into the firmware image when you compile. This would work, but is not ideal since it requires you to rebuild the firmware for every new FPGA image. We can streamline this process by leveraging the brilliance of the UF2 format created by Michal Moksal. We instead of converting the JBC data to a C include file and compiling it to an image that will eventually be converted to UF2, we can convert it directly into UF2 format. We just need to add a header with the file size of the JBC file.
Depending on what was running last on the Pico board, you may need to swap the firmware before adding the JBC data, and there could be compatibility issues between the firmware and JBC header. The simplest solution is to combine the JBC UF2 file with a compatible firmware image so that it works reliably regardless of what was previously loaded on the Pico board.
So this is what I did. I re-wrote the uf2conv.py script to take an existing UF2 firmware image, extract the family code, recalculate the number of blocks to include the JBC file and header, and concatenated the header uf2 block and the newly converted JBC blocks to file.
This new combined UF2 file can be drag-n-dropped onto the Pico board and will immediately program the FPGA through the pico-dirty-blaster adapter.
The pico-jbi.uf2 JBC player firmware and the uf2jbc.py generator script are available at the pico-dirty-blaster github repo.
Better bootloader
02/13/2023 at 02:49 • 0 commentsReceived the Arduino MKR Vidor 4000 this week.
First order of business is upgrading the bootloader. It is the same SAMD21 with the same LED pin as the MKR Zero so rebuilding the https://github.com/adafruit/uf2-samdx1 was very straightforward. All I really needed to do was change the drive label. Long term I probably need to get a new VID/PID for this board with the UF2 bootloader. I didn't want to wire up my CMSIS-DAP debugger, so I used the .ino file generated by uf2-samdx1 along with the Arduino IDE to update the bootloader.
Next, I wanted to start porting CircuitPython to allow me to access the FPGA with the JTAG library. I ran into some issues building mpy-cross that I still need to work through.
I'm continuing to look at strategies for loading images into the FPGA. If I were designing the board, I would probably connect the MCU up to the config flash in parallel, but I did not design this board so I am stuck with their connections. Reviewing the schematic in more detail I see that they only connected the JTAG signals. There are many of the I/O connected in parallel with the MCU I/O and to the header pins, so I could also use those as side channel to load images through a friendlier interface than JTAG. I am wondering how large an image would be that only wires up MCU I/O to the SPI signals for the configuration flash. If it is small enough, I can include it in the MCU code, so it can be loaded into the FPGA, then load the flash directly with a SPI interface. It would be easier to implement UF2 loading through a SPI interface than it would be through JTAG.
This begs the question. Where does the FPGA loading code belong? Should it be part of the MCU bootloader so that you can update both the MCU and FPGA images from the same bootloader? Or, does it belong in the MCU application? The bootloader should be small, so I need to consider the code size. It might be possible to fit an SVF processor in the bootloader, but I doubt there would be room for even the smallest FPGA image to use the SPI flash trick.
It is also worth considering what the MCU application will be doing along with the FPGA. The SAMD21 is not a power house. It will probably function mostly as a USB interface to the FPGA. It is reasonable to consider that the MCU application could contain both the FPGA update code and the FPGA interface code. CircuitPython might not be the ideal choice with the limited memory available on the SAMD21. It may force splitting the loading and interfacing code into separate images.
A minor detour
02/04/2023 at 22:11 • 0 commentsLast week I mentioned some libraries that would work well in this project, but I failed to mention that I was also considering CircuitPython. CircuitPython has a JTAG library, but it does not directly support SVF, so I was leaning towards libxsvf. That was before Chris Brown's blog "Profesional Video With Arduinos" reminded me that there is an Arduino board with an FPGA integrated. The Arduino MKR Vidor 4000 has an ATSAMD21G18A with a Cyclone 10CL016. The SAMD21 is already connected to the JTAG pins on the Cyclone 10LP, so this is an ideal development platform for processing SVF files.
The SAMD21 is very well supported by CircuitPython, but it is a little light on memory, especially without the extra SPI flash. We can probably make it fit if we limit the libraries to only what we need, or worst case we can go back to libxsvf in C. Either way, we can make use of the UF2 bootloader. The MKR Vidor is not supported by CircuitPython yet, but the MKR Zero is, and enough of the pins are the same that the bootloader is probably compatible. Since the chip is already supported, and the pinouts are so similar, it will be straightforward to add MKR Vidor support to CircuitPython.
So my minor detour is to use the MKR Vidor as a development platform, and to start development with CircuitPython. I think it would be good to have both libxsvf and CircuitPython solutions available so this is really just another path to the same result, thus a detour.
Choosing Libraries
01/29/2023 at 03:16 • 0 commentsIn the previous log I stated my current goal. To summarize the requirements:
- An SVF player
- Connects through USB CDC serial port
- Drives JTAG pins
- As portable as possible
I've spent some time looking for JTAG libraries, and libxsvf looks like the best candidate by far.
To keep this portable, I don't want to use vendor USB libraries. There are two options for an open USB stack I am considering. The first is Ha Thach's TinyUSB. I am a big fan of this project. Ha has done an incredible job creating a portable USB stack that supports an impressive list of MCUs. I have used this before on a few projects including Adafruit's TinyUF2.
The only other USB stack I can think of that might come close to supporting as many MCUs would be the one in the Zephyr project. The Zephyr project is also quite impressive. It is very professional and has great infrastructure tooling. There is a little bit more of a learning curve to use Zephyr and it is probably overkill for this initial effort.
I think I will start with TinyUSB, but I might port it to Zephyr later on to make it easier to add features like ethernet and SD cards. The number of open-source peripheral libraries in Zephyr are its biggest strength, and very likely why it is gaining so much momentum.
Hello again
01/24/2023 at 04:23 • 0 commentsAfter a prolonged hiatus, I am returning to this project.
I'm working with FPGAs again and remembering how frustrating the programmers are, and why I started this project. My previous attempt was diverted to software efforts for some off-the-shelf MCU boards. Last time I was spoiled by working with an FPGA (MachXO2) that supported SPI and I2C configuration ports, so I was able to avoid the pain of JTAG. This time I am not so fortunate.
I want an easy to use programming tool that will run on almost anything, without complicated software and target a variety of devices. Targeting a variety of devices can be simplified by using the SVF format which most FPGA tools know how to generate. In order to simplify the use and installation, I will run the majority of the code on an MCU and communicate over USB with a virtual COM port. Using a virtual COM port interface means you can use the default USB driver in the OS and possibly support multiple platforms without compiling apps on each.
To keep this accessible, I want to support the most cost effective MCUs available. Right now that would be the Raspbery Pi Pico which is one of the few MCUs you can find in stock, and the dev boards only cost $4. A bonus feature of the Pico RP2040 is the PIO programmable I/O, which may be helpful for accelerating the abomination of a serial protocol that is JTAG. NXP/Freescale FlexIO may also work for this, but those devices are harder to find at this time.
November Update
11/25/2018 at 16:50 • 0 commentsI haven't had much time and things are progressing slowly, but I have made some progress. I was able to add support for the on board flash in circuitpython so that it can be used for the circuitpy drive storage. The code is posted in my github repo: https://github.com/gsteiert/circuitpython
I added a new fpga_helper_express board in addition to the fpga_helper board to keep the option not to use the on board flash for circuitpython. The reason I want to keep this option is because circuitpython will put a file system on the flash that is not compatible with the internal SPI loader in the FPGA, and it will be difficult to share a single flash device with both circuitpython and the FPGA. When this circuit gets integrated on a board with the FPGA, I don't want to require two SPI flash devices. I will need to modify circuitpython to put the binary image on the flash without the file system so the FPGA can load directly from it. This work is TBD.
Another option would be to have circuitpython push the image from flash into the FPGA. The reason I am avoiding this is because many FPGA's from a variety of vendors can load from similar SPI flash that are straightforward to program. If were to push the code into the FPGA using circuitpython, I would have to customize it for every different target, which I would rather not do.
FPGA's with integrated storage are different story, since there is no external SPI device to program. The MachXO2/3 series from Lattice have internal non-volatile storage that can be loaded through JTAG, SPI or I2C. Since the I2C signals are so easy to get to with the qwiic connector, I think I will work to add support to configure the MachXO2/3 using circuitpython. Using the on board flash to cache the image in this case is not as much of a penalty if you are only using this board as a programmer and disconnect it when you are done. You can program as many targets as you want with the single programmer. The extra flash device is more of a burden if you are integrating it permanently.
September 30th Update
10/01/2018 at 05:10 • 2 commentsThe board is up and running and software development is making good progress.
The UF2 bootloader and CircuitPython are up and running on the board.
The dotstar LED and QWIIC I2C connector are both accessible through CircuitPython. Here is a link to a video showing the board fading the LED and reading a Qwiic NFCPROM:
https://www.instagram.com/p/BoYK98fFmnP/?utm_source=ig_share_sheet&igshid=dxhbtd1k2cwn
The obligatory blinking lights video
09/05/2018 at 03:17 • 0 comments -
It's alive!
09/03/2018 at 05:25 • 0 commentsI received the boards and they passed the smoke test. Great job MacroFab!
It didn't take too long to get the uf2-samdx1 bootloader running on it:
https://github.com/gsteiert/uf2-samdx1/tree/fpga-helper
I started working on circuitpython and seesaw ports, but those will take a bit more time. For now I will focus on the basic uf2 interface to the SPI flash.
Did I mention CircuitPython?
08/20/2018 at 00:26 • 0 commentsAs mentioned previously, UF2 was created to make it easier to work with CircuitPython. The boards upon which this circuit is based were designed to run CircuitPython and one of the first steps for bringing up and checking out this board will be to port and run CircuitPython. Having a board like this capable of running CircuitPython could almost justify the project on its own. This will be on of the first CircuitPython boards with any of Qwiic, UEXT, and PMOD connection options, let alone all three. CircuitPython also provides an easier way for FPGA developers create scripts and utilities in an environment that might be easier for them to work with than the native embedded C/C++.
greg
