1FINALIZING COMPONENTS REQUIRED
- PlutoX
- PrimusX board
- PrimusX breakout board
- MQ2 gas sensor
- Double sided tape
- Zip tie
2GETTING THE HARDWARE READY
- MQ2 sensor need a 5V Input.
- Solder the connector cables to GND, VCC, ADC pin out (Pin 19).
- Place the sensor and tie it properly.
3GETTING THE SOFTWARE READY
- Breakout board gives power to MQ2 sesnor
- Github link to read the sensor data
- Convert the input data to equivalent voltage
- Set some specific threshold, If the sensor data is greater than a threshold ARM the drone and Set a Specific height to take off.
SHIVANI
