I needed a sensor to accurately measure voltage and current. Most available solutions will only measure up to 5A or 36V or even less. I was planning to measure up to 10A and 60V. Therefore I needed to build my own.
With the resurrection of the " One Square Inch" contest I decided to enter my board into the competition.
I've barely even started populating this. The main targeted voltage is >36V for which the LTC4151 is ideal. For voltages less than 36V there are plenty of breakout board options available. I see no point in duplicating that which already exists.
