A high torque, high precision, Strain Wave Gear (harmonic drive) based 3D printable closed loop servo actuator for use in robotic arms
Placed an order for my first batch of custom Open HD 8318 motors.
I thought this would be worth publishing a log about.
While preforming a load test I found that the flexspline will start to rachet if too much reverse torque is applied. I find this interesting, I was under the impression that the first mode of failure with this version of the flexspline would be the teeth shearing off.
I'll be working on a fix for this issue over the next few days. A few ideas in mind have are:
I've also been given a suggestion by Gabrael Levine, the designer of OpenTorque Actuator, to alter the wave generator geometry to keep a preload on the flexspline. I shall see what works best and include it in the next Open HD revision.
That brings a revised wave generator, fixed spline, and output shaft assembly. There are now 3mm dowel pins of various lengths (40mm, 14mm, 8mm) placed throughout the fixed spline as well as output shaft assembly for precise mating and added structural support.
Changes to the wave generator were primarily processes focused to make their manufacturing simpler to automate. List of component changes:
Changes to the fixed spline consisted only of two component changes and some slight procces refinement.
Changes to the (upper) output shaft assembly
Integration of the still unfinished encoder head also came with the V 5.1. Currently the encoder head is using a transmissive photointerrupter (link). I will be switching to a Broadcom reflective sensor in the future, but for now I have some stock of the EE-SX1108 and they work fine as a placeholder till then.
The only post processing that needs to be done on the parts prior to assembly (inner race, outer race, and ball cage) is polishing the surfaces and cleaning up any printing artifacts.
Pre and post processing on the races and ball cage:
The only assembly steps after post processing are:
Amazing project! The last updates have been written a while ago, are you still working on this project? I would love to see the current state and maybe you are already far enough to upload your files. Best regards! :)
3B Basili parça dosyalarını yayınlayacak mısın? heyecanla yayınlamı bekliyoruz. Yapmayı istediğim projemde kullanmak çok isterim. Şimdiden teşekkürler.
Where are you at in this project? We are starting a robotic arm project and have been debating on whether to pursue a printed gear reducer or used Harmonic Drives. This looks like it could be a compelling fit for us!
Hey Tyler, as far as a ready for use and tested design goes, I'd say 3 more months. But I won't have the capacity to produce and sell them for another 9 months to a year. Once I finish the first round of thorough testing with the custom motors I'll post the part files.
I found an issue with deflection in last iteration of the design and have been working of fixing that. Also, I decided not to post files until I have a working encoder ready to use with it because it kinda doesn't make sense to use the drive without one.
Do you have the 3D printed parts files available? I'd love to try to make one of these. I've been wanting to do the same type of project and love that I found this one.
Hi John, stl and part files should be available in about 3-5 weeks. Things have been progressing quickly on my end over the past couple weeks. I want to make sure everything lives up to a minimum standard of usability before I publish the first round of files. Just so you know, the first round likely wont include working encoders. I just started to dig into the encoder redesign last week.
Also, if you do end up printing your own once they are available I'd love a critique and feed back.
I was wondering what BLDC motors you are using for this project?
Hello, Initially for testing I have been using:
For the production gear boxes I've been designing two different motors, one large (8318) and one small (8315). Both should still be quite torquey. I'm placing the order for the first batch of 8318's on the 20th of this month.
Here's the 8318:
https://drive.google.com/file/d/11p4OLDLRH3lzoCJz5e9bevfAxI0Il9hK/view?usp=sharing
Awesome, thanks! I see the JD powers have a order min of 50 pieces? I also saw in one of your images that you are using Tiger motors? How were those working for you?
Any idea on the rough torque outputs of your custom designed motors?
Also, I see you are using flexible filament for the flex shaft, any reason you wouldn't just use nylon with a thinner wall? I don't think you would see the back driving with a more rigid material?
No problem! The quantity threshold on the JD power motors is new... if you send them a message I think they will send you a single unit. I purchased a second unit yesterday and had no issues. As for the t-motor gb85-1, I salvaged those off an old gimbal I bought from someone. I only got them because it was a great deal at $150 for the entire gimbal! They didn't see more than a day of testing with the Open HD. Not the form factor I was looking for.
I really need to do some testing on the stock motor I have that the Open HD 8318 is based on. I don't have a setup to do that atm. I saw that you are in the Bay Area? If you have a way of characterizing torque, I have the motor and driver to do it. I'd gladly let you borrow it for a bit to do so (could also print adapters/mounts for anything that might need it).
As far as the flexspline being printed in TPU, it's because the tapered section needs to be able to radially deform a good bit to accommodate the wave generator. I plan on testing a nylon flexspline sometime soon, but for a different harmonic drive design that i'm working on that doesn't experience a significant radial deformation.
Are the files going to be posted somewhere so that we can make our own?
Hey Gravis, indeed they will be once complete. I estimate 3-4 more months until Open HD is in what I would consider to be a usable state. I will publish files then. I'm getting some custom 8318 BLDCs made to pair with Open HD, once I have those in hand I will be able to give a more certain time frame.
Wonderful work Sam. Please could you do a log on your flexible bearing design? I had a go but mine was rubbish!
Thanks Simon, glad this project caught your eye! I will. I’ll be adding much more info starting a week from now. On vacation at the moment
Hey Simon, took a bit but I've posted info about the wave generator
Looking good! Nice to see so much detail and a change log already.
newdrive
Tim Wilkinson
Simon Merrett
hello :) can you share cad file?
