11Connect optical and opto-electronic components
- Connect "LED" BNCH ouptpus to LED drivers for channels 1 and 2
- Connect "PD" BNC inputs to photodiodes for channels 1 and 2
- Connect "Sync In" and "Sync Out" BNCs as required for specific experiment
12Operation
- Plug in power
- Connect NI-DAQ USB-6009 to computer with USB
- Open Strathclyde WinEDR software on computer
- Navigate to Record-->Record to disk
- Navigate to File-->New and set file name
- You should see live traces on the screen but NOTHING IS BEING RECORDED YET
- Set the "Power" switch to "on"
- Set the "Record" switch to "off"
- Set the "Osc" switch for each channel such that the oscillation is off
- Turn the LEDs on one at a time using the LED driver and use the amplitude knob for each channel to set the light power for each channel
- Flip the "Osc" switch for each cannel to start the oscillation
- Set oscillation frequencies for each channel (I use 217 Hz for primary cannel and 319 Hz for secondary channel)
- Connect the optical fiber to the mouse and preview the signal in the WinEDR software
- Adjust light powers as necessary to obtain a raw signal and avoid saturation of raw fluorescence traces (channels 4 and 5)
- Adjust the "Gain" for each channel so that preview signals (1 and 2) are non-zero and non-saturating. Note, "Gain" affects only the preview signals. I recommend calculating final signals post-hoc from the raw fluorescence traces and ignoring the preview signals.
- Click "Record" on the StrathClyde WinEDR software. UNTIL THIS STEP, NO DATA IS BEING RECORDED
- Start behavioral protocol and flip "Record" switch on the box to "on" to lock values in place and start "Sync Out" TTL pulses
- Record session
- Click "Stop" on StrathClyde WinEDR software. NOTE: Even after you stop recording, your data file will remain open and locked by WinEDR until you either close the program or open a new file. Do not start a new recording without creating a new file or you will risk over-writing your previous session.
- Flip the "Record" switch to "off"
13Post-hoc analysis
- Unzip analysis scripts from "Post-hoc analysis scripts Matlab 20190426.zip"
- Add scripts to Matlab path
- Open the script fibPhotDemo.m
- Set the frequency ranges for each channel by adjusting the variables params.freqRange1 and params.freqRange2 at the top of the script
- Run the script and select the ".edr" file containing your photometry data
- Processed data will be stored in three variables:
- dsTimes -- Time stamps for each data point in processed data
- dsVals1 & dsVals2 -- Processed data for channels 1 & 2
- syncInTimes & syncOutTimes -- Time of TTL pulses
- Additional variables available
- rawVals1 & rawVals2 -- Data before photobleaching correction
- rawData -- Full data from ".edr" file
sfowen
Hello there! I'm currently using the PhotometryBox for my experiment!
However, I'm struggling with the synchronization of the module with a behavioral camera.
It would be ideal for me to have the camera acquisition triggered by the SyncOut channel. Still, the TTLs that come from this channel have a fixed frequency (1second). Is there a way to modify the frequency?
Thanks for the good work and the incredible piece of hardware!
Best,
Marco
Matlab post-hoc analysis scripts have been updated to correct how the cut-off frequency for the final low-pass filtering of the processed data is determined
