1Install Drivers
This step is not needed for the recent mainstream operating systems. But in case the Ph0xx is not recognized, try installing the drivers.
2Setup the Arduino IDE
Get yourself a recent version of the Arduino IDE and add "https://dl.espressif.com/dl/package_esp32_index.json" in the field for the additional boards manager URL ( File > Preferences )
Install the ESP32 toolchain through the boards manager. Open the Boards Manager ( Tools > Board > Boards Manager ) and search for ESP32. Press "Install"
3Install the Fri3d library
Download the ZIP file of our repository and follow the instruction described by Arduino to correctly install the library.
