Streaming the SensorTag Data
08/18/2018 at 12:18 • 0 comments![]()
This is a simple version of Node Red to capture the sensor data. I am streaming to IBM cloud and the Influx database I have created. There is no configuration of the data - it just works. I am testing on the Raspberry Pi 3. The Pi will act as a gateway. Data from the sensor tag will be saved by the Influx node. The port for influx is 8086 appended to the Pi's IP address. The data base has been set up in Influx and the measurement is called watch. A measurement is similar to a table. We need to define this to setup a data source in Grafana. -
Grafana and Influx
08/16/2018 at 17:53 • 0 commentsGrafana is a wonderful open source application to graph your sensor data in real time . You can refresh the data every 5 secs and store the data using Influx back end. To install Grafana on the Raspberry Pi go here and for Influx download here.
Alexa voice for Storm Watch
08/16/2018 at 17:10 • 0 commentsI did install Alexa for another project about two years ago. Boy it was a long progress and now it seems to have been simplified. I used this script to get the app up and running: Simple Alexa . Please note that the Product ID has to be my_device and the the Client ID is found under security management settings or its not going to work when you set up config.txt. I am using the ultra low cost Logitech C170 web cam for the microphone. I'll be updating the log with some testing of the microphone.
Brenda Armour
