Preliminary sdcard.asm
08/24/2018 at 14:04 • 1 commentI've uploaded the preliminary sdcard.asm source edit. It won't build due to undefined labels and a few typos have already been corrected
It's interesting to see how I can optimize the code even though I'm very new at 6809 assembly.
SD-Card in progress \o/
08/24/2018 at 02:52 • 1 commentAs S-BUG is working reasonably now, The next step is to move on to SD-Card access. @Dolo is generous enough to allow his SD-Card code to be used as a framework for the 6809v2 project. Make sure you check his projects out. Thanks Dolo!
