1Populate components
Except transistors and coils
2Fix transistors to heatsinks and solder to board
3Fix 350T coil to PCB with hot glue, and solder one end to pad on board
4Make the 2 turn coil
Make two turns of solid wire anticlockwise around the coil, about 30mm OD. Starting from the pad of L1 closest to the "1".
5Try it!
Apply 15-24V
