All files necessary to flash the ESP32. Uses a default WiFi of SSID "Lasertag", static MQTT Server at 192.168.250.1:1883, and it's MAC as PlayerID For now, reconfiguring these parameters requires compiling the firmware yourself - one day I'll add a terminal-based reconfigure
All 3D STL files that are necessary to print a casing. Multi-Material-Capable, for single material printing just leave out transparent and marking sections!
x-zip-compressed -
435.41 kB -
10/31/2019 at 15:02
