eyelashes-charlieplexed.pdf
Schematic in PDF
Adobe Portable Document Format -
120.19 kB -
09/04/2018 at 16:16
Preview
eyelashes-charlieplexed.ino
Arduino source code
ino -
34.08 kB -
09/04/2018 at 17:38
Download
eyelashes-charlieplexed.sch
kicad schematic
sch -
18.81 kB -
09/04/2018 at 16:16
Download
eyelashes-charlieplexed.kicad_pcb
kicad pcb. Beware! I etched my own boards and milled the outline using a dremel. There is a 0ohm jumper that can easily be removed by adding some vias. But vias are a pain when building your boards at home. So double check before sending it to a Fab for manufacturing.
kicad_pcb -
114.64 kB -
09/04/2018 at 17:44
Download
eyelashes-charlieplexed.net
kicad netlist
net -
18.50 kB -
09/04/2018 at 16:16
Download
gerbers.zip
Gerben's gerbers q-;
Zip Archive -
27.17 kB -
09/04/2018 at 17:49
Download
circle-leds-A4.pdf
I printed these arcs on transparency paper. I used superglue to temporarily attach the leds on the no-printed side. After soldering the wires, remove the leds from the sheet by soaking them in acetone.
51.95 kB -
09/05/2018 at 12:54
Preview
