EgyDuino
EgyDuino is an Arduino compatible board , Atmega8 USB interface , single side board , TH design , ATmega328 chip , Serial monitor
EgyDuino V1.2
The features of this board are:
- It's using ATmega8 as interface IC using CDC interface http://www.recursion.jp/avrcdc/
- Has USB connection to PC
- Standard RESET button
- Serial monitor with different Baud rates
- 100% compatible Arduino PINs
- 5V regulator
- 3.3V output
- Compatible size and design
- All component are TH (through hole) parts
- USB or DC power switch
- LED for PIN13 with Jumper
- LED for power
- ICSP PINs
- Easy to build with single size board , Through hole design , home made DIY PCB
- ATmega8,168,328 core and suitable for many bootloaders ; UNO , Duemilanove , NG
- standard DC power jack
EgyDuino_Gerber_files.zip
x-zip-compressed - 51.15 kB - 10/19/2016 at 20:54
Download
EgyDuino_PDF_files.zip
x-zip-compressed - 58.68 kB - 10/19/2016 at 20:53
Download
Rich text editor
Tiago wrote 07/06/2014 at 16:16 point
I think it needs a bit more functionality to have the edge (pardon the pun) over a regular arduino
Adam Fabio wrote 07/06/2014 at 04:49 point
Thanks for entering the Hackaday Prize! A simple to build USB enabled arduino sounds like a good idea. Out of curiosity, why did you go with CDC over standard V-USB?
Don't forget to keep the updates coming - you have to do a couple of videos to be eligible for the prize.
Dr Ayman Shalaby wrote 07/06/2014 at 10:04 point
Thank you Adam Fabio for your comment ,
V-USB does not support Arduino Serial monitor , and saving a space for code .
Regards
