1Some notes
The ESP-32 board pins operate in 3.3v levels while the Gravity pH and EC sensors operate in 5V. I inserted a simple voltage divider to shift 5v to 3.3v levels on the signal pins.
How to use the EC meter?
So how did it turn out? Are the Gravity sensors stable and accurate enough?
