Restoring a Beckman neon display clock
Making a large Panaplex display clock work again
Making a 30+ year old digital clock using a large Beckman 7-segment neon display work again
Prologue
First off, this is not cutting edge. If anything it's trailing edge.
In the late 1980s I bought a digital clock with large neon digits from a disposals store. I liked that the digits were 5 cm tall and a beautiful amber.
Here's the front of it:
Not very interesting but good contrast perspex. Here's the back of it:
This gave the first hint that it wasn't a conventional digital clock. The input and output connectors suggested that it was meant to run in a clock network.
Opening the clock revealed this:
The transformer provides 5V for the microcontroller via a rectifier capacitor circuit feeding a heatsinked regulator. A separate winding is rectified and filtered to provide the HV for the neon display. The primary of the transformer has two windings which can be jumpered in parallel or in series for 120V or 240V operation. The microcontroller is an 8035, which is essentially an 8048 without ROM. It is driven at 3.579545 MHz. The program memory is in the socketed 2716 chip. The driver transistors are the MPSA42 for the cathodes, and a MPSA42 coupled with a MPSA92 for the anodes. More on this later.
Turning it on got a blinking colon, then after a minute or two, the display would show 00:02. My guess is that on failing to acquire a synchronisation signal it went into free-running mode. The clock gradually lost time.
Beckman is a manufacturer of the Panaplex displays. Enquiries about the provenance of the clock on Usenet (ye olde days) drew a blank. Even now I can find no data about the display panel. My best guess is that the panel was specifically made for this line of clocks, intended to be sold both in the US and international markets.
In the 1990s I acquired an EPROM programmer driven by a PC running DOS. With that I was able to dump the contents of the EPROM with the idea of disassembling the code and working out how to feed it the serial signals it wanted. However reverse engineering machine code is for masochists or people who have to pick apart computer viruses, so I gave that up.
And so matters stood until earlier this year, when I had more time on my hands and decided that the display was too good to leave idle and I should try to made a conventional digital clock out of it by either (1) replacing the 8035 with a modern microcontroller, or (2) writing code and burning a replacement EPROM. The latter course of action required less hardware modifications so I decided to try this first. Thus was born this restoration project.
Stage 1
While casting around for things to make with my ancient 8048 family chips, I came across the 8048 Assembly Code Tomb by Steven Bjork. There was a project for an 8048 digital clock using a MC146818 real time clock chip. I have quite a few of these, extracted from old PCs, and also some of the DS1287 variant which combines a lithium cell. There were instructions on the Internet for using an external cell if the internal one had gone flat.
However on some pondering, I decided to not include an RTC but use the mains frequency for timekeeping, like consumer digital alarm clocks, because I wouldn't have to modify the circuit to interface the DS1287. The task of reinitialising the time on power cycle won't happen often.
So the design goals were:
  1. Display hours and minutes (duh) and blink the colon at 1 Hz
  2. Use the mains frequency as a timing source
  3. Have two buttons to set the hours and minutes
  4. Minimal modification of the existing circuitry
  5. Produce firmware for a replacement EPROM in the socket
I knew that I could use the multiplexed display driver circuitry as is. All I had to find out was the mapping of the anodes and cathodes to the 8048 ports.
Some circuit tracing with a continuity meter showed that the anodes were driven by the upper nybble of port 2, and the cathodes from port 1. A 1 level on a port 1 pin turned on the cathode transistor. For the anode drive, I found that the circuit was this:
Very clever, the MPSA42 is in common base configuration...
  • Signs of wear
    Ken Yap • 10/28/2024 at 06:50 • 0 comments
    Well it's in the nature of things to wear out, and this clock is no exception. After a few years of continuous operation, it can be seen that segments b, c and g are starting to shorten at their junction. No idea why it happened to the right edge of the rightmost digit. Maybe something to do with the plasma panel construction. Should be interesting to see how this will progress.
View project log
danjovic wrote 08/30/2021 at 10:13 • point
Quite beautiful display!
Ken Yap wrote 08/30/2021 at 10:19 • point
Thanks, I'm very pleased that I rescued it from the surplus shop all those years ago.
Entunassa wrote 07/10/2020 at 16:05 • point
There is nothing in display technology, comparable to the warm glow of a panaplex.
Ken Yap wrote 07/10/2020 at 16:11 • point
