ST offers a new STM8S device: the STM8S001J3 in an SO8N package. It's more powerful than the ATtiny85: same Flash, double the RAM, less EEPROM, better peripherals (ADC, 1x8bit+2x16bit timers, UART, I2C and half an SPI), and at a price of $0.20 it's much cheaper than the ATtiny85. It's even cheaper than the ATtiny13!
It has another advantage: there is an interactive (untethered) Forth for it! The dataasheet is very similar to that of the STM8S003F3P6, and I hope to receive samples soon. There is a new Wiki page with a feature comparison of different STM8S Low Density Devices. The bottom line is this: other than the pin count there aren't many differences!
The reason for the somewhat confusing list of pin properties is that multiple GPIOs are bonded to a pin (with the exception of pin 6). When GPIOs are used in parallel, pin8 can drive up to 80mA within the spec of the device!
One can argue that compared with 8pin AVR chips it has one pin less to play with (Vcap), but NRST (reset) obviously isn't needed for in-circuit-programming, and on the ATtiny85 side working without the RESET/dW feature isn't really fun. An untethered Forth for the ATtiny85 could settle the score but I couldn't find any.
For most applications the STM8003F3P6 is a better choice ($0.24@10pcs), but SO8N is so much easier to solder that it ranks high in the gadget rating ;-)
Oohhohoho that's awesome for my gig; very timely news thankyou!
I'm feeling numb after thinking about this. I was about to bit bang something in assembler on an ATtiny15 to load a microwave PLL with a different frequency for 10GHz use. Easy enough to do. But a tethered 8 pin micro running forth instead just stalls my though process. Has anyone found an online source for these chips yet?
mouser/digikey in stock right now
The maximum STM8S00x timer clock frequency is the CPU clock (e.g. HSI 16MHz).
I'm not an ATtiny25/45/85 expert but 64MHz seems to be "slightly" out of spec. There are many examples in the net that demonstrate the ATtiny85 can be configured to do that but I wouldn't bet my job on it.
64MHz timer clock is pretty impressive for an 8bit µC. The ATtiny85 appears to be a good fit for analog signal processing, provided that the coarse digitalization is compensated by some noise in the signal path, and matching filter design.
Since the STM8S001 provides two capable 16bit timer units (plus a simple 8bit timer). Applications that require 16bit PWM resolution are better served with any of the low-cost STM8S.
Agreed, it's horses for courses: not an replacement, but a more or less suitable alternative :-)
Of course, depending on the requirements the STM8S can be a little viable (or desirable) alternative to AVR, e.g. one might mangage to bit-bang USB with an STM8S but as the core uses pipelining, 32bit operant fetch, and variable instructions length (from 1 to 5 bytes) it won't be easy.
Here's a Forth for ATtiny2313:
https://wiki.forth-ev.de/doku.php/attiny
I'm guessing it shouldn't be hard to adapt for the '85.
MikroForth for the ATtiny2313 is much like xForth: there is neither compiler nor interpreter on the target. Forth code gets interpreted/compiled, and a hex file appears. The hex file can then be programmed into the µC with the help of a bootloader, and then tested in burn-and-learn fashion.
A tethered Forth would provide interactive features, and an untethered Forth (e.g. AmForth or STM8EF) is completely self-contained.
Your link for https://github.com/TG9541/stm8ef/wiki is missing a colon
Thanks! There was a nice HTTP://HTTPS:// in the href attibute ;-)
This IC actually has the STM8S003 chip bonded to SOIC-8 frame. The same chip, just watch out for pins conflict, as multiple chip pads are shorted-bonded to single pin.
Maybe it's the same chip but at least it's a different revision. The UART1_TX option on PA3 is new, and at least the STM8Sx003 samples I tested don't support that mapping (yet).
handily that's exactly what I want.. Great move by STM, I'm such a fan of that chip; so incredibly cheap yet really quite capable
I also think that the STM8S001J3M3 is a fine little chip!
I've now got the STM8S "UART1 Half-Duplex" feature working. The STM8S001J3M3 has this feature on PD5 (pin8), or on PA3 (pin5) (after setting OPT2 bits 0:1). However, there is no NRST, "access to PD1/SWIM" needs to be carefully managed, and using single-wire communication on pin8 solves this problem. I'm now fine-tuning e4thcom support for this use case.
I received a few samples before those chips were available in online shops. I spent a few days with them, testing GDB for STM8 and others. I wrote my remarks here https://hackaday.io/project/27250-mcu-how-tos-reviews-rants/log/66992-stm8s001j3-the-good-the-bad-and-the-ugly
GDB how-to is in works.
