box guide
raspberry pi controlled ws2812 strip behind boxes, tiny webserver and script to show what's where
also works as a display
Rich text editor
whiterabbit86 wrote 09/23/2018 at 09:34 point
Nice work !!
Vincent wrote 09/22/2018 at 17:28 point
why dont you draw a simple "receiver" module running a photodetector backed with a tiny MCU, one RGB LED and a CR2032? All (I mean one "receiver" per drawer) would grab the LED data stream sent by the requester's LED, for each "receiver" to check if the message contains his ID in order to "output" or "no output" (that is the question, and that's what this project is all about!! :)
Kind of a upgradable, binary, Li-Fi powered, display.. As my best friend would say "only few line of code" huh
davedarko wrote 09/22/2018 at 20:19 point
it's a project for a contest.
davedarko wrote 09/22/2018 at 20:21 point
and I don't want to buy 120 coin cells
davedarko wrote 09/22/2018 at 20:25 point
I'll probably mark them with a resistor or two and use some 4051 chips for muxing and scanning / reading the value.
morgan wrote 09/20/2018 at 23:01 point
I don't believe it works as a display (ahem, video) or at all (ahem, source).
davedarko wrote 09/21/2018 at 05:29 point
I haven't started anything, indeed. The inside of the box seems to allow for too much bleeding as well. We'll see what I can do about it...
morgan wrote 09/21/2018 at 15:10 point
Maybe putting the leds in a short tube will allow them to "project" forward more.
WooDWorkeR wrote 09/16/2018 at 21:52 point
Maybe build a PartKeepr plugin :D - https://www.partkeepr.org/
davedarko wrote 09/17/2018 at 04:37 point
comes times, comes wheel
PointyOintment wrote 09/17/2018 at 05:40 point
If that's an idiom, I don't think it's known in English
davedarko wrote 09/17/2018 at 07:37 point
@PointyOintment there's a bunch of idioms that translate horribly (word by word), this one is one of them and was not chosen by accident ;)
It actually translates to: with time comes advice, iirc. There's also "live life in full trains" - which should actually be something like "go through live with big steps (?)"
Frank Buss wrote 09/16/2018 at 11:36 point
Nice idea. Of course, you could just number the boxes as well (box 1, drawer A1, A2,.. A5, B1, B2..., box 2...) and the webpage would show the box and drawer numbers, but this wouldn't be as fancy.
davedarko wrote 09/16/2018 at 20:27 point
there are sooo many things I could and should do. But, I'll do it myyyyyyy wayyy *sinatraed*
actually it's all about them contest rules
