BinMonitored.zip
Source code (Compile in Arduino IDE with generic ESP8266 module selected).
x-zip-compressed -
12.73 kB -
10/01/2018 at 02:57
Download
BinMonitoreLidFull.dxf
Laser cutting file for a full width lid
AutoCAD DXF -
79.69 kB -
10/01/2018 at 00:04
Download
BinMonitoreLid.dxf
Laser cutting file for the smaller lid which fits inside the enclsure lip.
AutoCAD DXF -
80.03 kB -
10/01/2018 at 00:04
Download
BinMonitoreLid.svg
SVG original for Laser cutting file
svg+xml -
3.93 kB -
10/01/2018 at 00:04
Preview
BinMonitoreLidFull.svg
svg+xml -
4.12 kB -
10/01/2018 at 00:04
Preview
BinMonitoredBigLid.stl
Large lid, ideal if you use 3mm acrylic on the inner lip of the enclosre then put this on top .
simplify3d_stl -
370.98 kB -
10/01/2018 at 00:03
Download
BinMonitoredLid.stl
Normal lid, fits inside the lip.
simplify3d_stl -
245.39 kB -
10/01/2018 at 00:03
Download
BinMonitoredEnclosureBody-PCBRecessed.stl
Enclosure with the PCB recessed a little more so it can be encapsulated in epocy.
simplify3d_stl -
225.18 kB -
10/01/2018 at 00:02
Download
BinMonitoredEnclosure-5-Narrow.stl
Standard Enclosure
simplify3d_stl -
231.53 kB -
10/01/2018 at 00:02
Download
BinMonitored.sch
Eagle Schematic
sch -
484.70 kB -
09/30/2018 at 19:51
Download
BinMonitored.brd
Eagle board file
brd -
94.43 kB -
09/30/2018 at 19:51
Download
Pcb Top Layer
Portable Network Graphics (PNG) -
72.81 kB -
09/30/2018 at 19:51
Preview
PCB Bottom Layer
48.22 kB -
09/30/2018 at 19:51
Preview
Pcb (All Layers)
130.40 kB -
09/30/2018 at 19:50
Preview
Schematic
382.23 kB -
09/30/2018 at 19:50
Preview
BinMonitored-V1-Gerber.zip
Gerber
x-zip-compressed -
57.21 kB -
09/30/2018 at 19:50
Download
