STM8S Development Board
A project which aims to build a development board for STM8S003F3P6 (20 pin SMD) microcontroller.
This project aims to build a development board for STM8S003F3P6 (20 pin SMD) microcontroller. STM8 microcontrollers are 8-bit general purpose microcontrollers from STMicroelectronics (STM). They are robust, has a lot of features and are highly economical when it comes to price. STM8 MCUs are one of the most unexplored yet efficient microcontrollers and this project aims to provide a platform for enthusiasts to learn and appreciate them.
The development board features STM8S003F3P6 microcontroller (with 8-Kbyte flash memory, 1-Kbyte RAM, 128-byte EEPROM), external crystal for clocking, type B mini USB port, a USB to UART converter, voltage regulator, LED, switch , buzzer, potentiometer for ADC input and general purpose IO ports for user applications.
The STM8S003F3 microcontroller development board is designed primarily for general purpose applications. The microcontroller features 16 GPIO pins all of which can be accessed easily by the user through the male header pins provided along the sides of the board. Separate header pins are provided for programming the board through ST-Link programmer as well as for switching the operating voltage between 5V and 3.3V. The board can be powered up through USB cable as well as through the ST-Link programmer. The on-board 3.3V voltage regulator has a current capacity of 800mA and can power up the board as well as interfaced external peripherals. The Type-B mini USB port along with USB to Serial chip (CH340G) provides communication with PC.
Features of the development board:
  • STM8S003F3P6 microcontroller.
  • On-board 16MHz crystal oscillator
  • A Buzzer interface
  • One switch
  • One reset button
  • One user LED
  • A 10kohm potentiometer for ADC interface
  • USB Type-B mini port for powering up as well as for data transfer
  • On-board 3.3V voltage regulator - LM1117
  • On-board USB to serial chip CH340G for communication via UART
  • A 4 pin SWIM port for programming via ST-LINK programmer
  • On-board power selector pins for switching the operating voltage between 5V/3.3V
  • On-board power indicator LED
  • All port pins available through male header strips
  • Highly compact with dimensions of 4.53 cm x 7.6 cm
codes.zip
Test_codes
Zip Archive - 2.40 kB - 11/27/2018 at 02:20
Download
documentation.docx
document - 8.95 MB - 11/27/2018 at 02:10
Download
dev_board_new_BOM.txt
Bill Of Materials
plain - 16.66 kB - 11/27/2018 at 00:36
Download
STM8S003F3 datasheet.pdf
Adobe Portable Document Format - 1.47 MB - 11/26/2018 at 08:31
Preview
STM8S_dev.brd
Layout of the board
brd - 193.28 kB - 11/26/2018 at 08:35
Download
View all 8 files
  • 1 × STM8S003F3P6 IC Microcontroller IC
  • 1 × CH340G USB to UART converter IC
  • 18 × Capacitor
  • 10 × Resistor
  • 31 × Pin header GPIO pins, SWIM port and Power select
View all 13 components
View all 7 project logs
  • 1
    Schematic and layout designing
    Schematic and layout designing is done on the Eagle PCB design software. The design is made taken into consideration of the different requirements of the ICs used in the board. The important design aspect  to be taken care of is to choose the value of VCAP of the microcontroller. The value of the VCAP is to be choosen between 470nF and 1uF. If the value is not choosed carefully then the whole design wont work. The schematic and the layout files are uploaded in the files section.
  • 2
    PCB fabrication and soldering of the components
    The layout is checked and each layer is verified using Gerbview software. Then it is given for the fabrication. After the PCB is received, the components are soldered in the main PCB and are checked for any short connections.
  • 3
    Testing of development board and working of the peripherals
    The development board and the working of the peripherals is tested using the codes which are uploaded. The programmer used is ST-Link V2 and is programmed using the SWIM port . The compiler used for the codes is IAR Embedded Workbench.
View all 3 instructions
nadamo1002 wrote 09/29/2024 at 09:10 • point
Working with https://binary-studio.com/saas-application-development/ to develop our API was a great decision. Their team has developed a scalable and secure API that easily integrated with our existing platforms. I was particularly impressed with their attention to detail and high technical skill, which led to excellent results. They also demonstrated exceptional efficiency and responsibility at all stages of the project. Binary Studio is a reliable partner you can trust.
