25/11/18
11/26/2018 at 06:37 • 0 commentsThe main PCB is checked for the the working of different peripherals by programming the micro-controller with the ST-Link programmer and is found to be working as required.
22/11/18
11/26/2018 at 06:34 • 0 commentsThe components are procured and are soldered on the PCB board.
15/11/18
11/26/2018 at 06:32 • 0 commentsThe schematic design is made on the bread board and the design is checked.
12/11/18
11/26/2018 at 06:30 • 0 commentsThe fabricated PCB is received and tested for any corrections.
26/10/18
11/26/2018 at 06:26 • 0 commentsThe layout is sent for fabrication.
15/10/18
11/26/2018 at 06:25 • 0 commentsLayout of the PCB is made using Eagle software and is verified.
20/09/18
11/26/2018 at 06:20 • 0 commentsThe schematic design of the PCB is made in the Eagle PCB design software and is checked for corrections.
