SW20181025.zipThe ZIP contains the working SW status:- index.php, simas_n.js and style.css together are the assembler that runs in a browser. Live at www.enscope.nl/simas_nac. - clock.txt is the application SW that is a fully functional clock - mc_prog runs on the RPi and programs the microcode - 1sq_prog runs on the RPi, programs the application Flash, and can singlestep the processor x-zip-compressed - 36.59 kB - 10/25/2018 at 17:26 |
NAC1840.pdfSchematic of the DIP-IC version of the square inch CPUAdobe Portable Document Format - 25.42 kB - 10/20/2018 at 10:03 |
gerbers NAC1840.zipPCB gerber files for the DIP-IC version of the square inch CPUx-zip-compressed - 26.64 kB - 10/20/2018 at 10:01 |
CLK1840.pdfSchematic of the application pcb, "Clock".Adobe Portable Document Format - 47.59 kB - 10/20/2018 at 10:00 |
CLK1840 gerbers.zipGerber files for the 3.3 x 3 inch application pcb, "Clock"x-zip-compressed - 61.49 kB - 10/20/2018 at 09:59 |
Assembler code manual.docxDescribes the instructions of the CPUdocument - 31.90 kB - 10/20/2018 at 09:34 |
SQ1C1841.pdfNew PDF Schematic of the square inch CPU (with corrected flash chip pinout)Adobe Portable Document Format - 23.06 kB - 10/14/2018 at 10:22 |
gerbers SQ1C1841.zipPCB Gerber files of square inch cpux-zip-compressed - 20.01 kB - 10/14/2018 at 10:21 |
SQ1C1841.MAXOrcad pcb design of square inch cpumax - 673.56 kB - 10/14/2018 at 10:20 |
SQ1C1841.DSNOrcad schematic capture file of the square inch cpudsn - 401.00 kB - 10/14/2018 at 10:18 |
