1Components
NOTE: The R1 value is chosen for a dimly lit, red 7-segment display. The R2 value is chosen for a dimly lit red LED. Experiment to find values for R1 and R2 that suites your preference.
2PCB preparation
NOTE: The PCB is shown with traces facing down.
3MCU and ceramic cap
4Pin header preparation
5Switches, inputs and LED
6Resistors
7Wires
8Speaker, electrolytic cap, battery holder, boost module
The speaker terminals should be connected to the opposite side of the PCB.
Before soldering the speaker permanently, use a multimeter to measure it's current draw from MCU pins 7 and 8. If current draw on each pin exceeds 40 uA, use the configuration in the next slide (step 9) instead.
9Alternate speaker configuration
With this configuration only MCU pin 8 connects to the speaker. The other speaker terminal connects to ground.
10Modify 7-segment display
