Closure printed
09/27/2018 at 11:30 • 0 comments13 hours and 46 minutes to print the last part, 40mm/s, 0.1 layer, 30% infill.... Only to find out I forgot to update the button position as I had changed the pcb before ordering.... Anyway, the part looks nice, retro as I wanted... Gotta update the 3d model and reprint....
Nice wakeup
09/26/2018 at 06:08 • 0 commentsWhat's nicer thn waking up with your 3d print finished without a filament runout or a crash/warp/stick problem?
Now let's go for the closure, long 8 hours print though :)
Upper PCB and fan mount
09/25/2018 at 20:18 • 0 commentsThe second last part to print, if everything goes as planned. Looks rather complicated part, but this will ensure a pressure on the upper PCB, which was also kindly provided by JLCPCB to keep it on place and a mount for the 5v fan. Print time @50% infill, with support, 0.2mm layers, 50mm/s : 1h36
PCB positioning
09/24/2018 at 19:06 • 0 commentsWell, the main pcb attachement to the case was forgotten.... So this evening I quickly drew some holders for it, that I glued inside the box. On the final iteration I'll have slots for them for a placement without glue. The pcb now nicely sits inside the box. Next step is finalising the top closure
New back panel
09/24/2018 at 19:03 • 0 commentsThe need to have more vertical space brought a back panel rework for a much better result
Early stages
09/24/2018 at 18:57 • 0 commentsThe first tries...
Psycho
