The Fluxamasynth modules enable you to:
- Make your own MIDI instrument with unconventional analog sensors
- Create algorithmic compositions
- Use it in a homebrew pinball machine to generate music and sound effects
- Build an unusual percussion device
- Augment an analog instrument with a Fluxamasynth-based hyperinstrument
Here are some additional features:
- 14 bits of pitch bend range
- Access to fine and coarse tuning in cents
- Access to low level wavetable parameters
- Stereo line level output
- Master volume and per-channel volume control
- 4-band Equalizer
- Chorus, flange, delay effects
- 8 Reverb effects
- Spatial effects
The Fluxamasynth design files are available on Github and are released under the CERN Open Hardware license v1.2.
Fluxly
Clay Shippy
spark buzzer
trademark
Are there any plans for a crowdsourced campaign for these devices?
