Confirmed Idea_Attempt 3.1
10/11/2018 at 10:14 • 0 commentsPresentation Slides Update:
New Project Title: Little Thoughts + Tagline.
New: Project Description.
New: Visual References.
- Capsule Machine for users to interact with.
- Capsule balls for users to write messages and to put inside.
New: Structure Materials.
- MDF wood will be used for body structuring & support structures.
- 3D printing will be mainly used for internal mechanism.
10/11/2018 at 09:51 • 0 comments11 Oct 2018
Mechanics Reference
Video reference for capsule machine
- https://www.youtube.com/watch?v=tCOuWPpyK8ghttps://www.youtube.com/watch?v=tCOuWPpyK8g
- https://www.youtube.com/watch?v=LzXOh-4qAlE
- https://www.youtube.com/watch?v=tWORdDFjrm4
- https://www.youtube.com/watch?v=HnHLguMtf4Y
Mechanics Sketch
- Write a message and toss into the capsule machine
- (A) sensor detect if people toss the ball in, if yes the latch we open for the ball to enter the machine.
- At the same time the notch will be unlock, for use to spin
- (B) while spinning the notch the "ball holder" will lead the ball downwards to the collect area
How do the notch works
- There will be 2 latch blocking the notch from spinning
- Once the sensor is checked, another motor above the latch will pull it up
- and now user will be able to twist the notch.
Reference
- As reference common coin operated capsule machine, use coin to push up the latch
- In our case we use a motor to pull up the latch.
Idea_attempt2
10/06/2018 at 18:42 • 0 comments1 October 2018
- discussion on which idea to discard
- 3 ideas picked (capsule machine, time machine , turn table)
- Make ideas more solid (user experience, mood , etc
5 October 2018
- Decide on Capsule Idea
Brainstorm_attempt1
10/06/2018 at 18:40 • 0 comments24 Sep 2018
- explore on reference
- brainstorm idea
26 Sep 2018
- discussion
- decided 5 ideas (turn table, capsule machine, time machine , led heart, musical box)
