Hackaday.io Hackaday.io
Sign up Log in
Marabunta
Open source parametric stringed instruments
andrew-bensonAndrew Benson
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
2 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 11
    • View all
  • Logs 12
    • View all
  • Instructions 0
  • Discussion 2
  • The 2018 Hackaday Prize
View Gallery
915
2
2
1
Team (1)
  • andrew-bensonAndrew Benson
Join this project's team
hardware
ongoing project
2018hackadayprize
This project is submitted for
  • Hackaday.com Tip Line
  • Musical Instrument Challenge
This project was created on 10/08/2018 and last updated 7 years ago.
Description
Open source parametric musical instrument model that can be tailored to any size.
Details
Files
multiscale neck generator.ipt
Autodesk inventor file used for creating different sizes of instrument necks.
ipt - 425.00 kB - 03/29/2019 at 18:46
Download
unibody.stl
bass unibody for laminating
Standard Tesselated Geometry - 330.94 kB - 03/15/2019 at 05:03
Download
bass2.dwg
DWG Drawing - 4.13 MB - 10/08/2018 at 15:43
Download
unibody.dwg
DWG Drawing - 1.27 MB - 10/08/2018 at 12:58
Download
Components
  • 6 × Guitar Tuners 4L x 2R
  • 6 × Guitar Strings Player's choice
  • 1 × Body Wood See CAD files for dimensions
  • 1 × P-90 Pickup Standard size
  • 1 × Humbucker Pickup Standard size
View all 11 components
Project Logs
Collapse
  • New Short Video Description
    Andrew Benson • 03/29/2019 at 18:45 • 0 comments
  • CNC Prep
    Andrew Benson • 03/15/2019 at 21:22 • 0 comments
    We are getting ready to CNC carve the next 6 string guitar. Here is the latest version of the 3d model used to carve the wooden parts
    Layout Test 6 String Marabunta CNC (2) by praxism on Sketchfab
  • Progress
    Andrew Benson • 02/22/2019 at 16:31 • 0 comments
    Head over to sketchfab to explore 3d models of Marabunta made in January.
    Marabunta parameter check
    Bass animation test
  • File:Spider Wasp 2012-06-04-10.42 (27445676044).jpg
    Andrew Benson • 10/16/2018 at 09:08 • 0 comments
    "An orphan picture. Other than it is a spider wasp and came from the county I work in I don't know much more about this azure beauty. It was taken when we were first setting up the camera rig in 2012....so likely just fell between the cracks."
  • Robot Spider Hatchery
    Andrew Benson • 10/12/2018 at 08:44 • 0 comments
  • Rocktober
    Andrew Benson • 10/11/2018 at 02:30 • 0 comments
    Marabunta is on hold until the Denver Maker Faire ends this weekend. I will be hosting two booths, the robot spider petting zoo and the levitating laser vaporizer in the Colorado Inventors Showcase. The spiders are closely related to Marabunta, running a custom linux OS that was designed to function as a universal audio workstation. If all goes well, the Marabunta instruments will soon be able to control a swarm of tap dancing robot spiders.
  • Naming Conventions
    Andrew Benson • 10/10/2018 at 05:38 • 0 comments
    I tend to name my instruments after insects and spiders; When I started this project, I called it the hornet. It turns out that there is a hornet bass already on the market, even though there is no hornet guitar. As this system is designed to be capable of creating guitars, basses, mandolins, etc... It seemed worth it to change the name, and avoid the confusion of being the second electric bass called the hornet. Marabunta is a South American colloquialism for hornets that hunt spiders, and is an uncommon enough term that I was able to score the domain for marabunta.net.
  • schema
    Andrew Benson • 10/08/2018 at 16:23 • 0 comments
    underpants gnome scheme:
    create documentation on how to fabricate AN instrument, then rebuild structural geometry
    release geometry, and translate geometry to python/blender
    collect prize
    (pirate voice) steady as she goes
  • derple
    Andrew Benson • 10/08/2018 at 15:22 • 0 comments
    this is the midi control test... teensy 3.0
  • 4 string bass
    Andrew Benson • 10/08/2018 at 15:19 • 0 comments
View all 12 project logs
Log In/Sign up to comment
Sign up with Github
OR
Andrew Benson wrote 02/22/2019 at 05:24 • point
Unfortunately we can't post the 3d file required to build this instrument in DXF format. We can and will publish some 2d fretboard inlay files in dxf
jerome wrote 11/04/2018 at 13:17 • point
I, m very interesting by your project. Could you post your file in dxf format please
A capable robotics platform to explore Computer Vision, Machine Learning, and a 6dof grasping arm.
Project Owner Contributor
Reachy: Open Source Humanoid Robot
robotics-colabRobotics CoLab
Hackaday Prize 2020
Voice-controlled assistant robot to keep you company
Open Personal Assistant Robotic Platform
erik-knutssonErik Knutsson
Hackaday Prize 2019
Open, 3D printed, multi axis robot arm
Sixi robot arm
dan-royerDan Royer
Supplyframe DesignLab: 2022 Hackada…
A modular robot spider designed to fight fires and do preventative forestry maintenance.
XANDR the XTINGUISHER
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Marabunta", please tell us the reason.
Send message
Remove Member
