1Step 1
Install Java 8
3Step 3
In BowlerStudio, navigate to the Parametric Animatronic Head url https://gist.github.com/madhephaestus/e67b5f75f23c134af5d5054106e3ec40
4Step 4
Hit the green run button
5Step 5
In the Creature Lab window, right click on the parts laied out on the ground, and export to SVG
6Step 6
(OPTIONAL) right click on the head and change its parameters like size of head and eyes, length of snout, and which servos you have, which bolts, and what thickness material you will cut it out of.
7Step 7
Assemble and program a NodeMCU with the nunchuck to servo code https://github.com/madhephaestus/Halloween2016/tree/master/WiichuckDemo
8Step 8
Assemble head like its assembled in the 3d window, and wire up the servos to the NodeMCU breakout board
9Step 9
Add foam and fur to taste.
Kevin Harrington
