Street Sense Schematic-Power Conditioning-V01.pdf
Adobe Portable Document Format - 33.40 kB - 09/13/2019 at 15:05
Preview
Street Sense Schematic-CPU Module-V01.pdf
Adobe Portable Document Format - 70.13 kB - 09/09/2019 at 18:43
Preview
Street Sense Schematic-Spec Sensor Module-V01.pdf
Adobe Portable Document Format - 44.90 kB - 08/01/2019 at 14:39
Preview
Street Sense Schematic-V08.pdf
Version 8 of Street Sense air and noise pollution sensor unit
- added separate analog supply
- reading ADC using ADC ~DRDY signal and uPy interrupt
Adobe Portable Document Format - 74.90 kB - 05/14/2019 at 16:16
Preview
Street Sense Schematic-V07.pdf
Adobe Portable Document Format - 69.76 kB - 03/25/2019 at 16:52
Preview
Street Sense Schematic-V05.pdf
Version 5 of Street Sense air and noise pollution unit
- new ADS1219 ADC
Adobe Portable Document Format - 67.74 kB - 03/18/2019 at 16:37
Preview
Street Sense Schematic-V04.pdf
Version 4 of Street Sense air and noise pollution unit
3 changes to reduce noise created by boost converter
- added high side MOSFET switch
- added Schottky diode to USB/Battery select cct
- added capacitor to input of boost converter
Adobe Portable Document Format - 64.26 kB - 03/14/2019 at 23:08
Preview
Street Sense Schematic-V03.pdf
Version 3 of Street Sense air and noise pollution unit
Adobe Portable Document Format - 60.52 kB - 02/13/2019 at 22:21
Preview
traffic_and_wind.wav
10 second audio clip. Testing I2S microphone with new MicroPython I2S module. Sample rate used is 10k samples/second. Wind noise can be heard.
Waveform Audio File Format (WAV) - 195.04 kB - 11/06/2018 at 01:09
Download
ambulance.wav
10 second audio clip. Testing I2S microphone with new MicroPython I2S module. Sample rate used is 10k samples/second. A passing ambulance can be heard.
Download
