dash_plugin.dll
plugin to make ets 2 work with arduino (telementery data plugin) put it in you ets 2 root folder under bin/X64/plugins
x-msdownload -
47.50 kB -
11/13/2018 at 03:45
Download
plugin.cpp
file for the plugin
cpp -
12.36 kB -
11/13/2018 at 03:45
Download
options.cpp
file for the plugin
cpp -
2.94 kB -
11/13/2018 at 03:45
Download
serial.cpp
file for the plugin
cpp -
3.02 kB -
11/13/2018 at 03:45
Download
serial.hpp
file for the plugin
hpp -
1.89 kB -
11/13/2018 at 03:45
Download
options.hpp
file for the plugin
hpp -
2.21 kB -
11/13/2018 at 03:45
Download
plugin.def
file for the plugin
def -
111.00 bytes -
11/13/2018 at 03:45
Download
dash_plugin.txt
file for the plugin
plain -
375.00 bytes -
11/13/2018 at 03:45
Download
arduino_controller.ino
This is the actual Arduino programing file i will be using to make the cluster work with ets 2
ino -
6.84 kB -
11/13/2018 at 03:44
Download
