Hackaday.io Hackaday.io
Sign up Log in
MIDI-INOUT
MIDI IN, MIDI OUT module for Arduino
artis-labArtis Lab
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.2k views
0 comments
11 followers
  • Description
  • Details
  • Files 0
  • Components 9
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.2k
0
11
8
Team (1)
  • artis-labArtis Lab
Join this project's team
  • ArtisLab
hardware
completed project
arduino eurorack synth diy midi MIDI In MIDI OUT
This project was created on 11/14/2018 and last updated 6 years ago.
Description
MIDI IN-OUT is an expansion module for Arduino. It provides two ports: MIDI IN and MIDI OUT, to be able to receive and transmit MIDI messages through serial connections.
The MIDI OUT is used for data transmission and it have to be connected to the Arduino TX port. While, the MIDI IN make possible to receive serial messages using the Arduino RX port.
Components
  • 1 × 6n137 Opto and Fiber Optic Semiconductors and ICs / Optocouplers and Optoisolators
  • 1 × 1N4148 Discrete Semiconductors / Diodes and Rectifiers
  • 3 × 220 Ohm resistor
  • 1 × 470 Ohm resistor
  • 1 × 10k Ohm resistor
View all 9 components
Project Logs
Collapse
  • MIDI In-Out now available on tindie
    Artis Lab • 08/20/2020 at 07:56 • 0 comments
    More info here: https://www.tindie.com/products/ArtisLab/midi-in-out/
  • New PCB released
    Artis Lab • 05/12/2020 at 14:05 • 0 comments
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Project Owner Contributor
Arduino + MIDI library = USB MIDI Controller
jvsalatinojvsalatino
A MIDI Sound and Interface Card for the TRS-80 Model 1, III, and 4
MIDI-80 for the TRS-80
michael-wesselMichael Wessel
"Samson" is a percussion unit housed in a vintage suitcase. It is remotely controlled by a sequencer app via Bluetooth MIDI.
Drummer in a Suitcase
joejoe
Published worksheets bringing together a range of my music and stem projects using Arduino, MIDI and music.
SDEMP STEM and Music Worksheets
kevinKevin
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MIDI-INOUT", please tell us the reason.
Send message
Remove Member
