It is Microchip/Atmel Xplained mini/nano mEDBG debugger with some additional features:
- level translation,
- USB 5V VBUS Schottky diode protection,
- build in 3.3V LDO,
- target voltage jumper selector: 5V (4.7V actually), 3.3V, external/other,
- power, programming and target power sensing LEDs,
- hacked code responsible for MCU selection: it is possible to program and debug all MCUs with compatible interface : ISP/dWire (most megaAVR and tinyAVR), SWD (all Atmel's ARMs), UPDI (new megaAVR and tinyAVR: called "0" and "1" series), TPI (some small tinyAVR)
(a little bit outdated) table showing interfaces in AVR / SAM families:
vidmo
It works great. I tested it with ATmega328P and ATtiny1616 as far. It can program and debug, no surprise here :)
Andy
Dave Vandenbout
Alex
psmay
I explained to myself. AVR32DD14 debugging not working. Reading the signature and FUSEs works. Writing to program memory and EEPROM is impossible.
Attempting to write FLASH:
Error code 0x00 received from the debugger. Debugger command Memory write failed.
Severity: ERROR
ComponentId: 20100
StatusCode: 1
ModuleName: TCF command: Modules:writeToMemory failed.
(Microchip Studio 7 Version: 7.0.2594)
