Hackaday.io Hackaday.io
Sign up Log in
Bluetooth hotend for 3D printer
Not only less wires, but print faster and more stable
robertrobert
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.2k views
2 comments
2.7k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 7
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
3.2k
2
2.7k
20
Team (1)
  • robertrobert
Join this project's team
hardware
ongoing project
This project was created on 11/23/2018 and last updated 4 years ago.
Description
1, Reduce the 3D printer MCU pressure, and can print faster.2, No a lot of wires to motherboard,only need power supply wire.3, you can add more sensors easily, like filament sensors.4,more stable, because printer no need to worry about temperature out of control.5,no need worry bout the wireless is not stable or lost data, since no need to sync data with mother board.CC2541 is not only a Bluetooth but a MCU can control heater with PID pwm and read temperature with internal ADC , and the temperature signal no need sync with mother board like motor control signal.The changed marlin source code:https://github.com/hackaday3D/marlin_Atmel2560/tree/master/Marlin-BT/Marlin
Project Logs
Collapse
  • new board!
    robert • 12/22/2018 at 04:12 • 0 comments
  • auto level print
    robert • 12/15/2018 at 08:43 • 0 comments
    auto level print
  • printing more than 11 hours
    robert • 12/11/2018 at 15:38 • 0 comments
  • wirless endstop for 3D printer
    robert • 12/05/2018 at 08:48 • 0 comments
    here is a video that show the auto home trigger position precision every time.
  • use optical tracking tangled filament
    robert • 12/01/2018 at 09:20 • 0 comments
    use optical tracking tangled filament or run out
  • received filament optical tracking chip
    robert • 11/28/2018 at 10:40 • 0 comments
    optical tracking chip PAT9125
  • testing|:heater,temperature sensor,2 fans
    robert • 11/27/2018 at 07:29 • 0 comments
    there are one heater,temperature sensor,2 fans.
View all 7 project logs
Log In/Sign up to comment
Sign up with Github
OR
Clara Hobbs wrote 11/25/2018 at 04:29 • point
This seems interesting, but I can see a potential to create a whole lot of new problems in an attempt to solve the problem of too many wires running to the extruder.  Most of the issues I foresee have to do with latency and clock synchronization, but connection reliability is sure to be another one.  I'll be interested to see how you overcome these problems.
Martin wrote 11/27/2018 at 10:37 • point
Yes. So one could think about a separate microcontroller on the head with some kind of (wired) data bus, but I would not trust on a bluetooth link in this case.
It's easy to clean a 3D printer nozzle when it is heated by a soldering iron.
Project Owner Contributor
Clean 3D Printer Nozzle
xo-ne-unXo Ne Un
High capacity fluid extruder.
Fluid extruder for 3D printer
nfknfk
TrafficMonitor.ai built with edge ML for object detection and radar for speed monitoring
Traffic Monitor
glossyioglossyio
Usb phyton controlled heated bed for M3D 3d printer, making abs printing possible
Heated Bed for M3D 3d Printer
gorkyGorky
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Bluetooth hotend for 3D printer", please tell us the reason.
Send message
Remove Member
