Product Overview
I've used perspex/acrylic to create a manifold which allows water to enter and exit 3D printed growing pods. The pods connect to the manifold through a SnapQuik coupling; these are detachable water tight push connectors. The unit is then framed using 20X20 V_Slot extruded aluminium profile. The frame also houses an aquarium where the water pump and filter are submerged, iPrunes uses a 4 channel relay to control the three actuators; a pump, filter and grow light. The relay's are wired to a pi via a PCB which can also allow senor's to measure the systems input's if required.
