A3Ptiles_v2.9_20200829.tgz
The last known good v2.9, fixes, updates, and the first RS latches.
x-compressed-tar -
196.28 kB -
08/28/2020 at 23:52
Download
YGREC8_VHDL.20200727.tgz
Fixed the latches, minor fix, major effect !
x-compressed-tar -
315.66 kB -
07/27/2020 at 05:53
Download
A3Ptiles_v2.9_20200718.tgz
defined some standard 4-inputs gates, updated INC8, added Gray6, fixed a big bug with DFF
x-compressed-tar -
194.01 kB -
07/18/2020 at 04:51
Download
A3Ptiles_v2.8_20200324.tgz
Version 2.8 can generate the "simple" definitions.
x-compressed-tar -
163.07 kB -
03/24/2020 at 17:22
Download
PA3_definitions_simple_nodelay.vhdl
v2.8 Library "simple" implementation with direct definition and NO external dependency or analysis capability, for compatibility. No delay
x-vhdl -
76.33 kB -
03/24/2020 at 17:18
Download
A3Ptiles_v2.6_20191229.tgz
Last release of 2019, easier to integrate in other projects.
x-compressed-tar -
160.00 kB -
12/29/2019 at 20:11
Download
A3Ptiles_v2.6_20191228.tgz
Added "zombie" gates and ports to solidify v2.6
x-compressed-tar -
160.54 kB -
12/28/2019 at 02:31
Download
A3Ptiles_v2.6_20191225.tgz
added test4_cornercases
x-compressed-tar -
156.42 kB -
12/25/2019 at 23:00
Download
A3Ptiles_v2.6_20191224.tgz
minor cosmetic stuff, looks good
x-compressed-tar -
156.01 kB -
12/24/2019 at 23:33
Download
A3Ptiles_v2.6_20191223.tgz
Display DepthList : ok
x-compressed-tar -
155.75 kB -
12/23/2019 at 01:37
Download
A3Ptiles_v2.6_20191222.tgz
Depthlist re-implemented
x-compressed-tar -
155.07 kB -
12/22/2019 at 04:27
Download
A3Ptiles_v2.6_20191221.tgz
depth starts to work
x-compressed-tar -
154.98 kB -
12/20/2019 at 23:22
Download
A3Ptiles_v2.6_20191220.tgz
added/spun-off a proper generalised histogram package.
x-compressed-tar -
154.16 kB -
12/20/2019 at 18:19
Download
A3Ptiles_v2.6_20191216.tgz
can also extract the netlist of ALU8
x-compressed-tar -
153.14 kB -
12/16/2019 at 04:16
Download
A3Ptiles_v2.6_20191215.tgz
Netlist extraction works !
application/x-compressed-tar -
151.89 kB -
12/14/2019 at 22:39
Download
A3Ptiles_v2.6_20191213.tgz
v2.6 adds LUT16 and start to implement netlist extraction
x-compressed-tar -
149.46 kB -
12/13/2019 at 17:43
Download
A3Ptiles_v2.5_20191205.tgz
small but not insignificant tweak, the last/definitive release of v2.5
x-compressed-tar -
185.14 kB -
12/06/2019 at 00:15
Download
A3Ptiles_v2.5_20191203.tgz
v2.5 ! 10x faster for failure test, packages are reorganised, external files can contain the excluded states... it's a great release !
x-compressed-tar -
184.96 kB -
12/03/2019 at 06:45
Download
read_xcl.tgz
The prototype of the code that reads the exclude files
x-compressed-tar -
1.67 kB -
12/01/2019 at 19:05
Download
A3Ptiles_v2.4_20191201.tgz
Added long integers for histograms/counters, and also counts the total number of cycles to check all the failures (figure of merit for the future BIST)
x-compressed-tar -
177.05 kB -
12/01/2019 at 15:16
Download
A3Ptiles_v2.3_20191127.tgz
added : Toggle counter, "exclude" generic parameter
x-compressed-tar -
176.71 kB -
11/27/2019 at 04:44
Download
A3Ptiles_v2.3_20191124.tgz
Added ALU8, working partially but some fundamental problems need to be solved before it's "good"
x-compressed-tar -
175.64 kB -
11/24/2019 at 23:09
Download
A3Ptiles_v2.3_20191123.tgz
added some more doc and generic gates
x-compressed-tar -
125.57 kB -
11/22/2019 at 23:27
Download
A3Ptiles_v2.3_20191121.tgz
single-architecture version
x-compressed-tar -
90.16 kB -
11/21/2019 at 06:19
Download
A3Ptiles_v2.2_20191119.tgz
integration of 2 tests, exhaustive failure detection of INC8, pretty good !
x-compressed-tar -
91.15 kB -
11/19/2019 at 07:02
Download
A3Ptiles_v2pre20190825.tgz
Added latches and INC8, packaging/integration not done yet
x-compressed-tar -
88.83 kB -
08/25/2019 at 08:32
Download
A3Ptiles_v2pre20190813.tgz
Many enhancements ! meta-levels and other goodies...
x-compressed-tar -
32.71 kB -
08/13/2019 at 21:59
Download
A3Ptiles_v2pre20190811.tgz
GND/VCC + "non-binary" logic cone detection
x-compressed-tar -
7.66 kB -
08/11/2019 at 15:42
Download
A3Ptiles_v2pre20190810.tgz
now with sequential gates
x-compressed-tar -
6.75 kB -
08/10/2019 at 21:47
Download
A3Ptiles_v2pre20190809.tgz
a better working version of the new system
x-compressed-tar -
6.61 kB -
08/09/2019 at 20:24
Download
A3Ptiles_v2pre.tgz
incomplete preview of the new system, for debugging only
x-compressed-tar -
3.51 kB -
08/09/2019 at 04:19
Download
A3Ptiles.20190412.tgz
50 more gates from Christos and a bugfix
x-compressed-tar -
80.27 kB -
04/11/2019 at 22:50
Download
A3Ptiles.20190330.tgz
Some more gates and fixes
x-compressed-tar -
78.34 kB -
03/29/2019 at 23:19
Download
pa3_libguide_ug_.pdf
"IGLOO, ProASIC3, SmartFusion and Fusion Macro Library Guide for Software v10.1" ©2013 Actel/Microsemi
Adobe Portable Document Format -
1.21 MB -
03/29/2019 at 22:56
Preview
A3Ptiles.20190104.tgz
Newer, better version
x-compressed-tar -
77.46 kB -
01/04/2019 at 05:04
Download
A3Ptiles.tgz
The archive of gates, with license and example.
39.90 kB -
12/02/2018 at 13:07
Download
