ESP32 Development Board is for developers. And It provides a USB to USART Chip CP2102. Developers can use CP2102 to program and debug ESP32.
The ESP8266 started a small revolution by bringing WiFi to a small and cheap package that also had enough processing power and enough pins to get small things done. Now get ready to take your bite-sized WiFi capabilities to the next level with the ESP32 Development Board!
The development board breaks out all the module’s pins to 0.1″ headers and provides a CP2102 USB-TTL serial adapter, programming and reset buttons, and a power regulator to supply the ESP32 with a stable 3.3 V. Espressif doubled-down on the CPU resources for the ESP32 with a dual core, running at 160MHz and tons more pins and peripherals.
Features
Use ESP-32S, ESP-WROOM32 or ESP-32S-ALB Module
USB to UART CP2102 Chip
LDO output current about 800mA
Supports Auto download circuit
2 x Buttons for Reset and Boot
All ESP32 GPIO pins Available
Files
AnalogLamb__ESP32 Development Board_V2_SCH.pdf
Adobe Portable Document Format -
21.58 kB -
01/10/2017 at 05:50
Seriously??? You're just using this to promote your sales?!?!!? Get real...
